VPN Server Starts Using 100 % CPU suddenly
DIL Network Team
Hi, we are using the solution from last more than 2 years, but suddenly SoftEther VPN server start using the 100 % CPU, we move the VPN server to another server which have 24 core CPU but the result remain same, there is no change in network an no change in VPN users. We have another server also but that's working fine. no issue.
Re: VPN Server Starts Using 100 % CPU suddenly
Is it possible to show the VPN server configuration and log?
DIL Network Team
Hi, I have attached the config file(vpn_server1config.log) please rename this to vpn_server1.config and check, while i am trying to attached the log file it is showing file size too large.
I could not find a strange place.
How much VPN communication does that server have?
DIL Network Team
Around 200-250 connections
Marsel Hersen
Had the same issue
DIL Network Team
Yes, is there any support option through remote session or any contact number.
When CPU overload occurs, is there any anomaly with NIC traffic?
DIL Network Team
No, Nothing is got happened with NIC traffic, and it continuously using CPU above 95%, never comes below 90 %.
Is it operating in VM?
What OS is used for that server?
The local bridge is configured to a device with a strange name, what is it?
DIL Network Team
Is it operating in VM? NO Physical with 128 GB RAM 2 CPU with 12 core each
What OS is used for that server? Windows 2012 R2
The local bridge is configured to a device with a strange name, what is it? No strange name
DIL Network Team
Can some one is available to talk with us for same, we need help.
> declare LocalBridge0
> string DeviceName Microsoft$20Corporation$20(ID=0936734477)
The manufacturer's driver may not have been installed for this device.
DIL Network Team
we want to talk with you, on this. also need permanent support for this solution. Can some one talk with us on below contact no.
0124-4566300 (India)
I'm sorry but I'm not interested in a such support contract.
DIL Network Team
Ok, well any other option, because we are using this product in our production, so that's why we need a support for this. In case any issue we looses a lot.
