decrypt TLS using wireshark
pavangk1984
Post by pavangk1984 » Sat Jun 08, 2019 12:43 am
Hi Folks,
I am new to SoftEther.
Is there a way to dump TLS session keys (which are used to encrypt application data) in SoftEther?which in turn can be used to decrypt
Wireshark capture
Thanks,
Pavan
Re: decrypt TLS using wireshark
Post by cedar » Tue Jun 18, 2019 6:01 am
Modification of the source-code is required to dump the SSL session key.
Exporting the server's private key is easier.
