Hello everyone,
I have a problem with the creation of a virtual hub with the SoftEther VPN Server Manager.
I'm working with VMware with a vitualized Windows 10 in it.
First of all, when I start the VPN Server Manager as admin, I don't have the opportunity to create a Virtual Hub. It seems, that the Button is deactivated. Here is a link what I mean: https://ibb.co/P67bWjm
After searching on the Internet, I found some tips, which says, that I need to start the "vpncmd_x64.exe" as admin.
That's what I did. In the first steps, I set a new password for the Admin privileges.
After it I can choose the mods, which I need. Authentification is also working with the new password.
My problem is now, that I got an error, where I can't find any solution for windows. It looks like, that the password is wrong (I tried every pw and also try to set new one - without success.)
With this link you can see the Error Code: https://ibb.co/jMTrgRQ
Can someone help me to fix this problem?
Thanks & best regards,
Alex
