Hi guys,
So I have 2 Bare Metal servers site A and site B, currently running OPNsense 20.7. I have a openVPN connection site to site with internet access from Site B.
Both servers are remote and I want to setup SoftEther on Site A so that users can connect via a vpn protocol.
Both sites have 2x nics WAN/LAN
However before I go ahead and try to implement this, does SoftEther support UPNP? I have UPNP activated on Site A OPNsense server already... Should I disable it? It is essential I have this kind of functionality as the users will be using many ports due to the nature of their devices and also the same ports at the same time... So I am assuming I will require to have the NAT feature on SoftEther running too.
Finally for the NAT feature to work successfully as a DHCP server do I need to bridge SoftEther to the WAN or LAN nic of the hosting server Site A? Remember I am tunneling internet access from Site B but users connect to Site A.
Thank you very much in advance.
Arigatogozaimas!
Softether running on OPNsense setup
rassamf
Re: Softether running on OPNsense setup
it s a shame there isnt anyone here who can help on this.
However I have managed to set this up and all internet is routed via Site B but it seems that upnp is not working with opnsense and Softether. I will make another post asking about this.
