How to configure SoftEther VPN for office network with 2-factor authentication login option.
Suppose if any user want to connect office vpn then login has to be done through 2-factor authentication as secured connection
Please let me know the procedure
Thanks
2 factor authentication (multi-factor authentication) for VPN login
linuxaws
Re: 2 factor authentication (multi-factor authentication) for VPN login
SoftEther VPN does not support two-factor authentication.
You may be able to use a PKCS#11 device that supports two-factor authentication.
linuxaws
Thanks for the reply. What is PKCS#11
Do we need to integrate the PKCS#11 with softethor then. Can you please update on it
PKCS#11 is a signing API.
Security token device supports this API can be used for certificate authentication of SoftEther VPN.
linuxaws
Do we have any web url with steps for this integration and procedure
