Vpn is connecting with mobile internet but not connecting wifi
shubhamt
Post by shubhamt » Fri Jul 08, 2022 1:43 pm
Hello All
When i connect softethervpn client with wifi then it is not connect. But it is connect with mobile hotspot.
And but somewhere it is connect with wifi but not connect with mobile hotspot.
And ping is also comming with static ip but not connecting vpm client.
Can you please anyone tell me solution ?
Re: Vpn is connecting with mobile internet but not connecting wifi
Post by solo » Thu Jul 14, 2022 1:02 am
Yes, make sure the wifi's subnet is different from your VPN's server.
swarne
Post by swarne » Thu Jul 14, 2022 12:41 pm
Check your Internet server, make sure that you have changed your server and install VPN software again.
