Softether Client on Asus RT-AC68U
jakeycrx
Post by jakeycrx » Fri Sep 16, 2022 4:32 pm
I've setup the Softether client on my RT-AC68U and it connects to the 2 servers on 2 seperate machines and LAN's correctly with no errors reported in the log and I can see the session is active on the server side. The problem is that I can't ping anything, it's like it's not connected. If I connect to the same servers using a Windows client on my PC then all is good. I'm using the default settings, the only thing I changed was setting bool AllowRemoteConfig true so I could use the client manager.
I'm guessing I need to change something for the IP routing in the config but I thought all the routing was controlled by the server?
This is my config to the 2 seperate servers. They are on completely seperate LAN's and they both work fine if I connect using the Windows client.
# Software Configuration File
# You may edit this file when the VPN Server / Client / Bridge program is not running.
declare root
bool DontSavePassword false
byte EncryptedPassword xxxxxxxxxx
bool PasswordRemoteOnly false
string UserAgent Mozilla/5.0$20(Windows$20NT$206.3;$20WOW64;$20rv:29.0)$20Gecko/20100101$20Firefox/29.0
uint UseSecureDeviceId 0
declare AccountDatabase
declare Account0
bool CheckServerCert false
uint64 CreateDateTime 1663261259627
uint64 LastConnectDateTime 1663311158904
string ShortcutKey xxxxxxxxx
bool StartupAccount false
uint64 UpdateDateTime 1663284800290
declare ClientAuth
uint AuthType 3
byte ClientCert
xxxxxxxxx
byte ClientKey
xxxxxxxxx
string Username Jake
declare ClientOption
string AccountName New$20VPN$20Connection
uint AdditionalConnectionInterval 1
uint ConnectionDisconnectSpan 0
string DeviceName VPN
bool DisableQoS false
bool HalfConnection false
bool HideNicInfoWindow false
bool HideStatusWindow false
string Hostname xxxxxxxxx.softether.net
string HubName VPN
uint MaxConnection 1
bool NoRoutingTracking true
bool NoTls1 false
bool NoUdpAcceleration false
uint NumRetry 4294967295
uint Port 443
uint PortUDP 0
string ProxyName $
byte ProxyPassword $
uint ProxyPort 0
uint ProxyType 0
string ProxyUsername $
bool RequireBridgeRoutingMode false
bool RequireMonitorMode false
uint RetryInterval 15
bool UseCompress false
bool UseEncrypt true
declare Account1
uint64 CreateDateTime 1663311254888
uint64 LastConnectDateTime 1663311258900
string ShortcutKey xxxxxxxxxxx
uint64 UpdateDateTime 1663311254888
declare ClientAuth
uint AuthType 3
byte ClientCert
xxxxxxxxx
byte ClientKey
xxxxxxxxx
string Username Test
string AccountName Test
string Hostname xxxxxxxx.softether.net
string HubName VPN
bool NoTls1 false
uint Port 443
uint PortUDP 0
string ProxyName $
uint ProxyPort 0
uint ProxyType 0
declare ClientManagerSetting
bool EasyMode false
bool LockMode false
declare CommonProxySetting
string ProxyHostName $
uint ProxyPort 0
uint ProxyType 0
declare Config
uint KeepConnectInterval 50
uint KeepConnectPort 80
uint KeepConnectProtocol 1
bool NoChangeWcmNetworkSettingOnWindows8 false
bool UseKeepConnect false
declare RootCA
declare UnixVLan
declare VPN
bool Enabled true
string MacAddress xxxxxxxxxx
Re: Softether Client on Asus RT-AC68U
Post by solo » Sat Sep 17, 2022 1:28 am
Yeah, on Linux you may have to add a route before dhclient on the SE vNIC. No, the server doesn't do any routing.
