VPS problem with SoftEther VPN client
datawizard
Post by datawizard » Wed Oct 19, 2022 2:15 pm
Dear SoftEther Team
First of all I should thank you for your great software.
I have a VPS with a valid IP that I can connect it via remote desktop. I use SoftEther client to have a VPN client on my VPS.
As soon as the VPN client connects, I loose my remote connection to the VPS. And also lost my ip valid ping.
Do you have any recommendation for me to solve my problem?
Re: VPS problem with SoftEther VPN client
Post by solo » Wed Oct 19, 2022 10:52 pm
Disable firewalls, make a VPN connection and post, as code, the output of:
VPN server:
netstat -r
ipconfig /all
vpncmd localhost:port /server /password:*** /cmd BridgeDeviceList
vpncmd localhost:port /server /password:*** /cmd BridgeList
vpncmd localhost:port /server /password:*** /adminhub:@@@ /cmd SecureNatStatusGet
//replace: *** with SE admin password; @@@ with VPN hub's name
VPN client:
netstat -r
ipconfig /all
Redact public IP and private info, if any, but do not remove anything.
eddiewu
Post by eddiewu » Thu Oct 20, 2022 2:24 am
This is normal since when the VPS connects to the VPN, all traffic is redirected to the VPN.
You need to add a static route back to the remote desktop client.
