help me ,VPN client can not ping bridged physical NIC IP.
SuppeRabbit
Post by SuppeRabbit » Tue Nov 22, 2022 4:49 am
SoftEther VPN Server Virtual Hub can obtain the MAC address of the client and the bridged physical NIC, but the client cannot ping the bridged physical NIC IP.
please help me ,thanks!
SuppeRabbit
Re: help me ,VPN client can not ping bridged physical NIC IP.
Post by SuppeRabbit » Tue Nov 22, 2022 5:26 am
And i have not enable SecureNat, The mac address of the client side cannot be obtained on the server side, but all mac addresses can be seen on the virtual bridge management interface.
Post by solo » Tue Nov 22, 2022 6:01 am
Disable firewalls, make a VPN connection and post, as code, the output of:
VPN server:
netstat -r
ipconfig /all
vpncmd localhost:port /server /password:*** /cmd BridgeDeviceList
vpncmd localhost:port /server /password:*** /cmd BridgeList
//replace: *** with SE admin password
VPN client:
netstat -r
ipconfig /all
sc query dhcp
