object not found
boudy6000
object not found
i have a problem whenever i click new virtual network adapter it takes too long to make it , then it appears and when i click on enable virtual network adapter or delete it it sends me “ object not found “ and when i click windows network connections it doesnt show vpn client so whats the solution please
Re: object not found
Try this:
- unistall SE client
- Device Manager > View > Show hidden devices: check
- Device Manager > Network adapters: delete all "VPN - VPN Client *"
- delete all C:\WINDOWS\inf\oem*.[i|p]nf(s) with "NeoAdapter_VPN" in them
- reboot, re-try
- reboot, re-try
boudy6000
i deleted the vpn clients in device manager there was a yellow triangle on them but i havent found \oem* in c
i have a problem that whenever i download any vpn app i get a yellow triangle in vpn client of it
They are definitely there, eg on my OS it's "oem7":
E:\>findstr /i neoadapter C:\Windows\inf\*.inf
So, I'd delete:
C:\Windows\inf\oem7.inf
C:\Windows\inf\oem7.pnf
C:\Windows\inf\oem7.inf:%NeoAdapter.DeviceDesc% = NeoAdapter.Install, NeoAdapter_VPN
C:\Windows\inf\oem7.inf:[NeoAdapter.Install]
C:\Windows\inf\oem7.inf:AddReg = Neo.Reg, NeoAdapter.Ndi
C:\Windows\inf\oem7.inf:[NeoAdapter.Install.Services]
C:\Windows\inf\oem7.inf:[NeoAdapter.Ndi]
C:\Windows\inf\oem7.inf:HKR, Ndi, DeviceID, , "NeoAdapter_VPN"
C:\Windows\inf\oem7.inf:NeoAdapter.DeviceDesc = "VPN Client Adapter -VPN"
