Softether OpenVPN has no internet after connection
rko4all
Post by rko4all » Sun Nov 27, 2022 8:10 pm
Hello There ,
I have installed softether vpn server on centos 7 and using softether VPN server manager , I have enabled openvpn . The problem is when I connect to VPN using OpenVPN connect windows app , it successfully connects but has no internet and no traffic .
Here is my OVPN config :
client
remote 78.135.*.* 443
dev tun
proto udp
auth-user-pass
resolv-retry infinite
redirect-gateway def1
persist-key
persist-tun
nobind
cipher AES-256-CBC
ncp-disable
auth SHA256
ping 5
ping-exit 60
ping-timer-rem
explicit-exit-notify 2
script-security 2
remote-cert-tls server
route-delay 5
verb 4
<ca>
-----BEGIN CERTIFICATE-----
MIID+jCCAuKgAwIBAgIBADANBgkqhkiG9w0BAQsFADB8MSMwIQYDVQQDDBp2cG4z
MTc4ODAzNTYuc29mdGV0aGVyLm5ldDEjMCEGA1UECgwadnBuMzE3ODgwMzU2LnNv
ZnRldGhlci5uZXQxIzAhBgNVBAsMGnZwbjMxNzg4MDM1Ni5zb2Z0ZXRoZXIubmV0
MQswCQYDVQQGEwJVUzAeFw0yMjExMjcxNjMwMjBaFw0zNzEyMzExNjMwMjBaMHwx
IzAhBgNVBAMMGnZwbjMxNzg4MDM1Ni5zb2Z0ZXRoZXIubmV0MSMwIQYDVQQKDBp2
cG4zMTc4ODAzNTYuc29mdGV0aGVyLm5ldDEjMCEGA1UECwwadnBuMzE3ODgwMzU2
LnNvZnRldGhlci5uZXQxCzAJBgNVBAYTAlVTMIIBIjANBgkqhkiG9w0BAQEFAAOC
AQ8AMIIBCgKCAQEAyoWsZ2Nwitdzc5af4coOKHnfT4oQxL1hmoBuBrZCueekwpIj
sXjj048U+k80HZa/wLJA29OwnhmG9X8bfBoWl/tl3ker9M5orIDalvIr5FyiWKHH
kwFe2I6iibE98rNpUUNnialmljtDGC6BXMxSe2HDJRg4904ZPVL8y2golFqK4uvl
JalwWjLw8VLWqxWWIHG3W4nyKVn00H3+s/dRJHf29g1kE4vOkIPbfJLMO/r4mtAn
W7sxlY8WmNtwkzks769yDR+IwU6VtezQuxXSMeXEmTaE+n3C/tt38Qz/2JOH7Owx
WdAn0LQ+xhnazN6IJmI6OY3ejzUgQFMCOq1x4wIDAQABo4GGMIGDMA8GA1UdEwEB
/wQFMAMBAf8wCwYDVR0PBAQDAgH2MGMGA1UdJQRcMFoGCCsGAQUFBwMBBggrBgEF
BQcDAgYIKwYBBQUHAwMGCCsGAQUFBwMEBggrBgEFBQcDBQYIKwYBBQUHAwYGCCsG
AQUFBwMHBggrBgEFBQcDCAYIKwYBBQUHAwkwDQYJKoZIhvcNAQELBQADggEBAGFI
u+q+tS9hlpyynFO6LmXXhTvVnC3EfLovyjbBzklJOPl+w+wLmgArFnvsU5aRIQxG
nKyGzVlf/iiPQqA5IHPZ4q/NyMQbaQ56pgUwnBAdUTxUnYJKAQnxHqa68jmvsmrs
xF8RyVa8wWGSN+/9oCGk+jyx0GEymETjjUeOLzT1+N/SNsbf31pUJkWriwWv4OhQ
kSd7g5aY1eYgi4fQSIULEmfv4QrVR+tb+Y2xY5MyPi3Jw+Nn4LycOVHBzx5qPc6w
46KzTnt6lt3asd3EhDi+FOXj93s2IAk2WyDuI5PU17eoXnCiTGPLrfWcoowjXKOJ
zWsX8vn8EZ0KCX+vJms=
-----END CERTIFICATE-----
</ca>
<cert>
MIIDGjCCAgKgAwIBAgIBADANBgkqhkiG9w0BAQsFADAMMQowCAYDVQQDDAEqMB4X
DTIyMTEyNzE4MjkxM1oXDTMyMTEyNDE4MjkxM1owDDEKMAgGA1UEAwwBKjCCASIw
DQYJKoZIhvcNAQEBBQADggEPADCCAQoCggEBAOiKc2DzJzPGvySNxDkNUxFPzVxv
CZoRvDoR/7aY9tyIep3ldCqVUGPRx3I8Fz8cbMiYHpD13aaF6Lt4+tpeZIvsTCWT
gVQbTdjHkw+V6Iq6oCdeAFBS/xP+rQUpSfaZj+7hZuUSwnIC4yj6EsfkKpexHyIi
GPP6bZSCzyAzirNKe0GjckDdqdwYCfKyAMLkuiO3Ikda9FxZHIKMC8H4Bh5RyfUP
w2PyISf4VUY/S85j9CyKTl98Mfy6WT1dAceEEilA37D6BjwBWljDQ+oosWv0iot1
/4m4DXz9/T/+B31but5zKf36Iry1baG7H4wFI47huoDP84VkTGopwL2ts2MCAwEA
AaOBhjCBgzAPBgNVHRMBAf8EBTADAQH/MAsGA1UdDwQEAwIB9jBjBgNVHSUEXDBa
BggrBgEFBQcDAQYIKwYBBQUHAwIGCCsGAQUFBwMDBggrBgEFBQcDBAYIKwYBBQUH
AwUGCCsGAQUFBwMGBggrBgEFBQcDBwYIKwYBBQUHAwgGCCsGAQUFBwMJMA0GCSqG
SIb3DQEBCwUAA4IBAQBAEHxUc6E3GBs+8ApLAE1pWGGTKMpcL1pX1zxFkm5z3gab
Ekqb1Ja7urU2pNRf9yKFV+TSCKo13dlqqiH9FN2ZUIGqS3HpAFW2G/OktaypqnkK
EdJ8/LZCWsFVoS7mf650viQfVfPjSHNjF+oXEDnRkV7tu0aFB4xk1ksfAvQ8oAVH
f7ppr6zPa2dB1rUMMW0pBnkWTqb67D0X9F3ny3uQbbfaWIg4QtqSDDSWvtx4ByDm
cVe6MlkRUxGyxJpyEhASRNtr3hcap2wFvZptLdjVE36xOpVTrwm9SKhnrprlUNek
M9jv2bkh2Crk0mW+3Q6TewmnaVE00BBTClWfoxb3
</cert>
<key>
-----BEGIN PRIVATE KEY-----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-----END PRIVATE KEY-----
</key>
Here is my softether VPN config file :
# Software Configuration File
# You may edit this file when the VPN Server / Client / Bridge program is not running.
declare root
	uint ConfigRevision 62
	string Region TR
	declare DDnsClient
		bool Disabled false
		byte Key h6th1Pb8Qk0plnWGabISbRd1ZWM=
		string LocalHostname mta2
		string ProxyHostName $
		uint ProxyPort 0
		uint ProxyType 0
		string ProxyUsername $
	declare IPsec
		bool EtherIP_IPsec false
		string IPsec_Secret vpn
		string L2TP_DefaultHub VPN
		bool L2TP_IPsec false
		bool L2TP_Raw false
	declare ListenerList
		declare Listener0
			bool DisableDos false
			bool Enabled true
			uint Port 443
		declare Listener1
			bool Enabled true
			uint Port 992
		declare Listener2
			bool Enabled true
			uint Port 1194
		declare Listener3
			bool Enabled true
			uint Port 5555
	declare LocalBridgeList
		bool DoNotDisableOffloading false
	declare ServerConfiguration
		bool AcceptOnlyTls true
		uint AutoSaveConfigSpan 300
		string CipherName AES128-SHA
		uint CurrentBuild 9760
		bool DisableDosProction false
		bool DisableIPsecAggressiveMode false
		bool DisableJsonRpcWebApi false
		bool DisableOpenVPNServer false
		bool DisableSSTPServer true
		bool DontBackupConfig false
		bool EnableVpnAzure false
		bool EnableVpnOverDns false
		bool EnableVpnOverIcmp false
		byte HashedPassword DX55YvyMxjERMFvi3bQ6SkEPXK0=
		uint KeepConnectInterval 50
		uint KeepConnectPort 80
		uint KeepConnectProtocol 1
		uint MaxConcurrentDnsClientThreads 512
		uint MaxConnectionsPerIP 256
		bool NoLinuxArpFilter false
		bool NoSendSignature false
		string OpenVPNDefaultClientOption dev-type$20tun,link-mtu$201500,tun-mtu$201500,cipher$20AES-128-CBC,auth$20SHA1,keysize$20128,key-method$202,tls-client
		string OpenVPN_UdpPortList 443
		bool SaveDebugLog false
		byte ServerCert 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
		byte ServerKey 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
		uint ServerLogSwitchType 4
		uint ServerType 0
		bool StrictSyslogDatetimeFormat false
		bool Tls_Disable1_0 false
		bool Tls_Disable1_1 false
		bool Tls_Disable1_2 false
		bool Tls_Disable1_3 false
		bool UseKeepConnect true
		bool UseWebTimePage false
		bool UseWebUI false
		declare GlobalParams
			uint FIFO_BUDGET 10240000
			uint MAX_BUFFERING_PACKET_SIZE 2560000
			uint MAX_HUB_LINKS 1024
			uint MAX_IP_TABLES 65536
			uint MAX_MAC_TABLES 65536
			uint MAX_SEND_SOCKET_QUEUE_SIZE 2560000
			uint MAX_STORED_QUEUE_NUM 1024
			uint MEM_FIFO_REALLOC_MEM_SIZE 655360
			uint MIN_SEND_SOCKET_QUEUE_SIZE 320000
			uint QUEUE_BUDGET 2048
			uint SELECT_TIME 256
			uint SELECT_TIME_FOR_NAT 30
			uint STORM_CHECK_SPAN 500
		declare ServerTraffic
			declare RecvTraffic
				uint64 BroadcastBytes 275073
				uint64 BroadcastCount 3666
				uint64 UnicastBytes 21801418
				uint64 UnicastCount 38362
			declare SendTraffic
				uint64 BroadcastBytes 113343
				uint64 BroadcastCount 946
				uint64 UnicastBytes 21702471
				uint64 UnicastCount 38214
		declare SyslogSettings
			string HostName $
			uint Port 514
			uint SaveType 0
	declare VirtualHUB
		declare VPN
			uint64 CreatedTime 1669534203294
			byte HashedPassword +WzqGYrR3VYXrAhKPZLGEHcIwO8=
			uint64 LastCommTime 1669547211734
			uint64 LastLoginTime 1669547040661
			uint NumLogin 15
			bool Online true
			string RadiusRealm $
			uint RadiusRetryInterval 500
			byte RadiusSecret aWJzbmc=
			string RadiusServerName 51.210.*.*
			uint RadiusServerPort 1812
			string RadiusSuffixFilter $
			byte SecurePassword bpw3X/O5E8a6G6ccnl4uXmDtkwI=
			uint Type 0
			declare AccessList
			declare AdminOption
				uint deny_bridge 0
				uint deny_empty_password 0
				uint deny_qos 0
				uint deny_routing 0
				uint max_accesslists 0
				uint max_bitrates_download 0
				uint max_bitrates_upload 0
				uint max_groups 0
				uint max_sessions 0
				uint max_sessions_bridge 0
				uint max_sessions_client 0
				uint max_users 0
				uint no_cascade 0
				uint no_change_access_list 0
				uint no_change_cert_list 0
				uint no_change_crl_list 0
				uint no_change_groups 0
				uint no_change_log_config 0
				uint no_change_msg 0
				uint no_change_users 0
				uint no_delete_iptable 0
				uint no_delete_mactable 0
				uint no_disconnect_session 0
				uint no_enum_session 0
				uint no_offline 0
				uint no_online 0
				uint no_query_session 0
				uint no_read_log_file 0
				uint no_securenat 0
				uint no_securenat_enablenat 0
			declare CascadeList
			declare LogSetting
				uint PacketLogSwitchType 4
				uint PACKET_LOG_ARP 0
				uint PACKET_LOG_DHCP 1
				uint PACKET_LOG_ETHERNET 0
				uint PACKET_LOG_ICMP 0
				uint PACKET_LOG_IP 0
				uint PACKET_LOG_TCP 0
				uint PACKET_LOG_TCP_CONN 1
				uint PACKET_LOG_UDP 0
				bool SavePacketLog true
				bool SaveSecurityLog true
				uint SecurityLogSwitchType 4
			declare Message
			declare Option
				uint AdjustTcpMssValue 0
				bool DisableHttpParsing false
				bool DisableIPParsing false
				bool DisableIpRawModeSecureNAT false
				bool FilterBPDU false
				bool FilterIPv4 false
				bool FilterIPv6 false
				bool FilterNonIP false
				bool FilterOSPF false
				bool FilterPPPoE false
				bool ManageOnlyPrivateIP true
				uint MaxSession 0
				bool NoArpPolling false
				bool NoEnum false
				bool NoIpTable false
				bool NoIPv4PacketLog false
				bool NoIPv6AddrPolling false
				bool NoIPv6PacketLog false
				bool NoLookBPDUBridgeId false
				bool NoMacAddressLog true
				bool NoManageVlanId false
				uint RequiredClientId 0
				string VlanTypeId 0x8100
			declare SecureNAT
				bool Disabled false
				bool SaveLog true
				declare VirtualDhcpServer
					string DhcpDnsServerAddress 8.8.8.8
					string DhcpDnsServerAddress2 8.8.4.4
					string DhcpDomainName $
					bool DhcpEnabled true
					uint DhcpExpireTimeSpan 7200
					string DhcpGatewayAddress 10.0.0.1
					string DhcpLeaseIPEnd 10.0.0.254
					string DhcpLeaseIPStart 10.0.0.10
					string DhcpPushRoutes $
					string DhcpSubnetMask 255.0.0.0
				declare VirtualHost
					string VirtualHostIp 10.0.0.1
					string VirtualHostIpSubnetMask 255.0.0.0
					string VirtualHostMacAddress 5E-E0-2B-C5-41-EF
				declare VirtualRouter
					bool NatEnabled true
					uint NatMtu 1500
					uint NatTcpTimeout 1800
					uint NatUdpTimeout 60
				declare CertList
				declare CrlList
				declare GroupList
				declare IPAccessControlList
				declare UserList
					declare *
						string AuthRadiusUsername $
						uint AuthType 4
						uint64 CreatedTime 1669537877007
						uint64 ExpireTime 0
						string Note $
						uint NumLogin 15
						string RealName $
						uint64 UpdatedTime 1669541391660
						declare Traffic
							declare RecvTraffic
								uint64 BroadcastBytes 76412
								uint64 BroadcastCount 815
								uint64 UnicastBytes 13619846
								uint64 UnicastCount 21535
							declare SendTraffic
								uint64 BroadcastBytes 39483
								uint64 BroadcastCount 139
								uint64 UnicastBytes 8022775
								uint64 UnicastCount 15254
			declare Traffic
				declare RecvTraffic
				declare SendTraffic
also I have already enabled SecureNAT . I have no idea why after connecting , I have no internet .
Any help is appreciated.
rko4all
Re: Softether OpenVPN has no internet after connection
Post by rko4all » Sun Nov 27, 2022 9:57 pm
update :
config works perfectly on android and iOS devices using OpenVPN connect . It seems the issue of having no internet when connecting to this vpn server , is only happening on windows version of OpenVPN connect . any ideas ?
also one more question . ncp-disable exists on my client config (ovpn file) . should I do anything on softether server to make sure it matches with client config regarding ncp-disable?
Post by solo » Mon Nov 28, 2022 1:48 am
Hi, make a VPN connection and post, as code, from the client:
netstat -r
ipconfig /all
sc query dhcp
OpenVPN connection log //presumably from OpenVPN-2.5.8-I602-amd64.msi
rko4all
Post by rko4all » Mon Nov 28, 2022 10:01 am
netstat -r output :
netstat -r
Interface List
 20...00 ff d5 ae 4f f7 ......TAP-Windows Adapter V9
 11...00 ff 76 66 36 d4 ......TAP-Windows Adapter V9 for OpenVPN Connect
 21...f0 2f 74 46 50 33 ......Realtek PCIe GbE Family Controller
 14...90 cc df cf 55 9f ......Microsoft Wi-Fi Direct Virtual Adapter
  3...92 cc df cf 55 9e ......Microsoft Wi-Fi Direct Virtual Adapter #2
 22...44 45 53 54 4f 53 ......Kerio Virtual Network Adapter
 10...90 cc df cf 55 9e ......Intel(R) Wi-Fi 6 AX201 160MHz
  5...90 cc df cf 55 a2 ......Bluetooth Device (Personal Area Network)
IPv4 Route Table
Active Routes:
          0.0.0.0          0.0.0.0      192.168.1.1    192.168.1.102     36
          0.0.0.0        128.0.0.0        10.0.0.14        10.0.0.13    257
        10.0.0.12  255.255.255.252         On-link         10.0.0.13    257
        10.0.0.13  255.255.255.255         On-link         10.0.0.13    257
        10.0.0.15  255.255.255.255         On-link         10.0.0.13    257
    78.135.*.*  255.255.255.255      192.168.1.1    192.168.1.102    291
        127.0.0.0        255.0.0.0         On-link         127.0.0.1    331
        127.0.0.1  255.255.255.255         On-link         127.0.0.1    331
  127.255.255.255  255.255.255.255         On-link         127.0.0.1    331
        128.0.0.0        128.0.0.0        10.0.0.14        10.0.0.13    257
      192.168.1.0    255.255.255.0         On-link     192.168.1.102    291
    192.168.1.102  255.255.255.255         On-link     192.168.1.102    291
    192.168.1.255  255.255.255.255         On-link     192.168.1.102    291
        224.0.0.0        240.0.0.0         On-link         127.0.0.1    331
        224.0.0.0        240.0.0.0         On-link         10.0.0.13    257
        224.0.0.0        240.0.0.0         On-link     192.168.1.102    291
  255.255.255.255  255.255.255.255         On-link         127.0.0.1    331
  255.255.255.255  255.255.255.255         On-link         10.0.0.13    257
  255.255.255.255  255.255.255.255         On-link     192.168.1.102    291
Persistent Routes:
  None
IPv6 Route Table
Active Routes:
 If Metric Network Destination      Gateway
  1    331 ::1/128                  On-link
 11    281 fe80::/64                On-link
 10    291 fe80::/64                On-link
 10    291 fe80::d286:61f4:cb64:c1d/128
                                    On-link
 11    281 fe80::fa4a:8370:1902:986c/128
                                    On-link
  1    331 ff00::/8                 On-link
 11    281 ff00::/8                 On-link
 10    291 ff00::/8                 On-link
Persistent Routes:
  None
ipconfig /all output :
ipconfig /all
Windows IP Configuration
   Host Name . . . . . . . . . . . . : LAPTOP-P363HOEA
   Primary Dns Suffix  . . . . . . . :
Ethernet adapter Ethernet 3:
   Connection-specific DNS Suffix  . :
   Description . . . . . . . . . . . : TAP-Windows Adapter V9
   Physical Address. . . . . . . . . : 00-FF-D5-AE-4F-F7
Unknown adapter Local Area Connection:
   Description . . . . . . . . . . . : TAP-Windows Adapter V9 for OpenVPN Connect
   Physical Address. . . . . . . . . : 00-FF-76-66-36-D4
   Link-local IPv6 Address . . . . . : fe80::fa4a:8370:1902:986c%11(Preferred)
   IPv4 Address. . . . . . . . . . . : 10.0.0.13(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.252
   DHCPv6 IAID . . . . . . . . . . . : 285278070
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-27-44-B5-0B-F0-2F-74-46-50-33
   DNS Servers . . . . . . . . . . . : 8.8.8.8
                                       8.8.4.4
Ethernet adapter Ethernet:
   Description . . . . . . . . . . . : Realtek PCIe GbE Family Controller
   Physical Address. . . . . . . . . : F0-2F-74-46-50-33
Wireless LAN adapter Local Area Connection* 1:
   Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
   Physical Address. . . . . . . . . : 90-CC-DF-CF-55-9F
Wireless LAN adapter Local Area Connection* 2:
   Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #2
   Physical Address. . . . . . . . . : 92-CC-DF-CF-55-9E
Ethernet adapter Ethernet 4:
   Description . . . . . . . . . . . : Kerio Virtual Network Adapter
   Physical Address. . . . . . . . . : 44-45-53-54-4F-53
Wireless LAN adapter Wi-Fi:
   Description . . . . . . . . . . . : Intel(R) Wi-Fi 6 AX201 160MHz
   Physical Address. . . . . . . . . : 90-CC-DF-CF-55-9E
   Link-local IPv6 Address . . . . . : fe80::d286:61f4:cb64:c1d%10(Preferred)
   IPv4 Address. . . . . . . . . . . : 192.168.1.102(Preferred)
   Lease Obtained. . . . . . . . . . : Monday, November 28, 2022 12:05:40 PM
   Lease Expires . . . . . . . . . . : Monday, November 28, 2022 2:05:59 PM
   Default Gateway . . . . . . . . . : 192.168.1.1
   DHCP Server . . . . . . . . . . . : 192.168.1.1
   DHCPv6 IAID . . . . . . . . . . . : 110152927
                                       1.1.1.1
Ethernet adapter Bluetooth Network Connection:
   Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
   Physical Address. . . . . . . . . : 90-CC-DF-CF-55-A2
sc query dhcp output :
sc query dhcp
SERVICE_NAME: dhcp
        TYPE               : 30  WIN32
        STATE              : 4  RUNNING
                                (STOPPABLE, NOT_PAUSABLE, ACCEPTS_SHUTDOWN)
        WIN32_EXIT_CODE    : 0  (0x0)
        SERVICE_EXIT_CODE  : 0  (0x0)
        CHECKPOINT         : 0x0
        WAIT_HINT          : 0x0
OpenVPN connect log :
⏎11/28/2022, 1:24:22 PM OpenVPN core 3.git::662eae9a win x86_64 64-bit built on Oct 27 2020 12:49:07
⏎11/28/2022, 1:24:22 PM Frame=512/2048/512 mssfix-ctrl=1250
⏎11/28/2022, 1:24:22 PM UNUSED OPTIONS
5 [resolv-retry] [infinite]
7 [persist-key]
8 [persist-tun]
9 [nobind]
11 [ncp-disable]
14 [ping-exit] [60]
15 [ping-timer-rem]
16 [explicit-exit-notify] [2]
17 [script-security] [2]
19 [route-delay] [5]
20 [verb] [4]
⏎11/28/2022, 1:24:22 PM EVENT: RESOLVE ⏎11/28/2022, 1:24:22 PM EVENT: WAIT ⏎11/28/2022, 1:24:22 PM Contacting 78.135.*.*:443 via UDP
⏎11/28/2022, 1:24:22 PM WinCommandAgent: transmitting bypass route to 78.135.*.*
	"host" : "78.135.*.*",
	"ipv6" : false
⏎11/28/2022, 1:24:22 PM Connecting to [78.135.*.*]:443 (78.135.*.*) via UDPv4
⏎11/28/2022, 1:24:22 PM EVENT: CONNECTING ⏎11/28/2022, 1:24:22 PM Tunnel Options:V4,dev-type tun,link-mtu 1569,tun-mtu 1500,proto UDPv4,cipher AES-256-CBC,auth SHA256,keysize 256,key-method 2,tls-client
⏎11/28/2022, 1:24:22 PM Creds: Username/Password
⏎11/28/2022, 1:24:22 PM Peer Info:
IV_VER=3.git::662eae9a
IV_PLAT=win
IV_NCP=2
IV_TCPNL=1
IV_PROTO=2
IV_GUI_VER=OCWindows_3.2.2-1455
IV_SSO=openurl
⏎11/28/2022, 1:24:22 PM SSL Handshake: CN=vpn317880388.softether.net, TLSv1.3, cipher TLSv1.3 TLS_AES_256_GCM_SHA384, 2048 bit RSA
⏎11/28/2022, 1:24:22 PM Session is ACTIVE
⏎11/28/2022, 1:24:22 PM Sending PUSH_REQUEST to server...
⏎11/28/2022, 1:24:22 PM EVENT: GET_CONFIG ⏎11/28/2022, 1:24:23 PM OPTIONS:
0 [redirect-gateway] [def1]
1 [ping] [3]
2 [ping-restart] [10]
3 [ifconfig] [10.0.0.13] [10.0.0.14]
4 [dhcp-option] [DNS] [8.8.8.8]
5 [dhcp-option] [DNS] [8.8.4.4]
6 [route-gateway] [10.0.0.14]
7 [redirect-gateway] [def1]
⏎11/28/2022, 1:24:23 PM PROTOCOL OPTIONS:
  cipher: AES-256-CBC
  digest: SHA256
  compress: NONE
  peer ID: -1
⏎11/28/2022, 1:24:23 PM CAPTURED OPTIONS:
Session Name: 78.135.*.*
Layer: OSI_LAYER_3
Remote Address: 78.135.*.*
Tunnel Addresses:
  10.0.0.13/30 -> 10.0.0.14 [net30]
Reroute Gateway: IPv4=1 IPv6=0 flags=[ ENABLE REROUTE_GW DEF1 IPv4 ]
Block IPv6: no
Add Routes:
Exclude Routes:
DNS Servers:
  8.8.8.8
  8.8.4.4
Search Domains:
⏎11/28/2022, 1:24:23 PM EVENT: ASSIGN_IP ⏎11/28/2022, 1:24:23 PM SetupClient: transmitting tun setup list to \\.\pipe\agent_ovpnconnect
	"confirm_event" : "5c0f000000000000",
	"destroy_event" : "4c0a000000000000",
	"tun" :
		"adapter_domain_suffix" : "",
		"block_ipv6" : false,
		"dns_servers" :
				"address" : "8.8.8.8",
				"ipv6" : false
				"address" : "8.8.4.4",
				"ipv6" : false
		"layer" : 3,
		"mtu" : 0,
		"remote_address" :
			"address" : "78.135.*.*",
			"ipv6" : false
		"reroute_gw" :
			"flags" : 275,
			"ipv4" : true,
			"ipv6" : false
		"route_metric_default" : -1,
		"session_name" : "78.135.*.*",
		"tunnel_address_index_ipv4" : 0,
		"tunnel_address_index_ipv6" : -1,
		"tunnel_addresses" :
				"address" : "10.0.0.13",
				"gateway" : "10.0.0.14",
				"ipv6" : false,
				"metric" : -1,
				"net30" : true,
				"prefix_length" : 30
	"wintun" : false
POST np://[\\.\pipe\agent_ovpnconnect]/tun-setup : 200 OK
TAP ADAPTERS:
guid='{766636D4-1A4A-4059-BD1C-B69B3948CD0B}' index=11 name='Local Area Connection'
Open TAP device "Local Area Connection" PATH="\\.\Global\{766636D4-1A4A-4059-BD1C-B69B3948CD0B}.tap" SUCCEEDED
TAP-Windows Driver Version 9.24
ActionDeleteAllRoutesOnInterface iface_index=11
netsh interface ip set interface 11 metric=1
Ok.
netsh interface ip set address 11 static 10.0.0.13 255.255.255.252 gateway=10.0.0.14 store=active
netsh interface ip add route 78.135.*.*/32 10 192.168.1.1 store=active
The object already exists.
netsh interface ip add route 0.0.0.0/1 11 10.0.0.14 store=active
Ok.
netsh interface ip add route 128.0.0.0/1 11 10.0.0.14 store=active
Ok.
netsh interface ip set dnsservers 11 static 8.8.8.8 register=primary validate=no
netsh interface ip add dnsservers 11 8.8.4.4 2 validate=no
NRPT::ActionCreate names=[.] dns_servers=[8.8.8.8,8.8.4.4]
ActionWFP openvpn_app_path=C:\Program Files\OpenVPN Connect\OpenVPNConnect.exe tap_index=11 enable=1
permit IPv4 DNS requests from OpenVPN app
permit IPv6 DNS requests from OpenVPN app
block IPv4 DNS requests from other apps
block IPv6 DNS requests from other apps
allow IPv4 traffic from TAP
allow IPv6 traffic from TAP
ipconfig /flushdns
Successfully flushed the DNS Resolver Cache.
TAP handle: 7c0e000000000000
⏎11/28/2022, 1:24:23 PM Connected via TUN_WIN
⏎11/28/2022, 1:24:23 PM EVENT: CONNECTED bvsnew@78.135.*.*:443 (78.135.*.*) via /UDPv4 on TUN_WIN/10.0.0.13/ gw=[10.0.0.14/]⏎
Post by solo » Mon Nov 28, 2022 12:54 pm
Look mate sorry, there is no nice way to put it, but you have a hell of a messy setup.
"OpenVPN core 3.git::662eae9a win x86_64 64-bit built on Oct 27 2020"
- why are you running such an old version?
"Interface List
11...00 ff 76 66 36 d4 ......TAP-Windows Adapter V9 for OpenVPN Connect"
- why do you have TWO OpenVPN taps?
Forget the commercial OpenVPN Connect and use only OpenVPN Community Edition.
You need to clean it up first and redo the logs. Proceed as follows...
- uninstall all OpenVPN progs, then next...
- Device Manager > View > Show hidden devices: check
- Device Manager > Network adapters: delete all "TAP-Windows Adapter *"
- reboot
- install only OpenVPN-2.5.8-I602-amd64.msi
- make a VPN connection and post, as code, from the client: tracert 1.1.1.1
EDIT
wait, I see some firewall, also disable firewalls/IDS too.
rko4all
Post by rko4all » Mon Nov 28, 2022 2:46 pm
I will do as you said but I don't think the setup is what causing the issue . the reason I say that is because I have multiple openvpn servers that currently work on windows with openvpn connect app but they are not created with softether server . It seems this issue is only happening on windows and is only happening with the Openvpn server that was created via softether .
Post by solo » Mon Nov 28, 2022 10:22 pm
Also please do not alter the ovpn config generated by your server. Especially do not add "redirect-gateway def1" as it is automatically requested by the server.
