Hi all,
I'm configuring SoftEther VPN Server (Developer Edition - DE) to work with OpenVPN Client 2.6.git using TLS 1.3 handshake protocol, but not work. Same configuration but when used with Stable Edition (SE) works fine. In addition, I have also configured SoftEther VPN Server (DE version) to work successfully with OpenVPN CLient using TLS 1.2 handshake protocol.
To change the configuration between the TLS 1.2 and 1.3 handshake versions, I change the client-side configuration file as follows:
tls-version-min 1.2
tls-version-max 1.2
or
tls-version-min 1.3
tls-version-max 1.3
Thanks everyone for the suggestion.
Developer Edition (DE) not work OpenVPN when using TLS 1.3
lucpv
