Client to Client Connection
valant98
Post by valant98 » Mon Mar 20, 2023 9:47 am
Hello everyone,
First of all i have 2 computers in two different networks and a Softether Server in the Cloud of Azure.
The computer (1) connects to the server via Softether Client and Computer (2) with OpenVPN client.
The connection between those 2 computers are successful using SecureNat. Is there a way that computer (1) can see the whole network of computer (2) and communicate with all devices in its network?
shakibamoshiri
Re: Client to Client Connection
Post by shakibamoshiri » Mon Mar 20, 2023 10:49 am
Yes there is.
You can install a vpnbridge (VPN Bridge) on computer 2.
These tutorials can help you
https://www.softether.org/4-docs/2-howto
valant98
Post by valant98 » Mon Mar 20, 2023 1:50 pm
As i mentioned the two computers are clients that connect to Softether Server in Cloud.
Isn't the installation of VPN Bridge specifically for server?
I have looked into the documentation but i cant find anything similar to my problem.
I would much appreciate a more specific guidance.
Thank you!
shakibamoshiri
Post by shakibamoshiri » Mon Mar 20, 2023 3:19 pm
SoftEther has three separate part
- vpn-server
- vpn-bridge
- vpn-client
In your case you need all three
what you need to download (or build)
That side you liked to expose whole internal network, you will install "SofEther VPN Bridge"
That side you liked to be normal, you will install "SofEther VPN Client"
For connecting these two clients, you will install "SoftEther VPN Server"
here is how
- install SE server
- add a hub
- at two users
- install SE bridge on computer 2 (enable SeucreNAT)
- add a cascade connection from SE bridge (on computer 2) to SE server (on could) -- use one of user credentials created
- install SE client (or any other client could connect to a SE server) and connect to SE server
At this point computer 1 should be able to access computer 2 internal network
You can ping the computer 2 local IP address from computer 1
topology of your need
[ computer 1 (SE client) ] =======> [ could with public IP (SE server) ] <======= [ computer 2 (SE bridge) ]
valant98
Post by valant98 » Thu Mar 23, 2023 8:26 am
Thanks a lot for the reply.
The only problem with the solution you provided is that the second computer is running openvpn client.
Shall i ask this question in openvpn forum?
shakibamoshiri
Post by shakibamoshiri » Thu Mar 23, 2023 1:46 pm
SoftEther is a multi protocol VPN. It supports
- OpenVPN
- SSTP
- L2TP
It is up to you
Post by solo » Fri Mar 24, 2023 1:24 pm
It's a generic routing question which can be answered here. As you're not telling anything about OS' and subnets I'll use the following for illustration.
SE server
Virtual DHCP: 192.168.22.10-200 no default gateway
LAN1
PC1 192.168.8.1
LAN2
PC2 192.168.111.105
PC3 192.168.111.101
- from the server get "openvpn_site_to_site_bridge_l2.ovpn" config
- mod it if necessary (eg forwarded port/protocol, cipher/data-ciphers, etc.)
- on PC2 set OpenVPN TAP NIC to a static IP, eg 192.168.22.2
- on PC2 run services.msc and start the "Routing and Remote Access" service
- on PC2 start the OpenVPN client
on LAN2's router add static route:
ip route add 192.168.22.0/24 via 192.168.111.105
- if the router does not support static routes, add persistent static route to every PC which needs to cross-connect:
route -p add 192.168.22.0 mask 255.255.255.0 192.168.111.105
- on PC1 start the SE client
- on PC1: route add 192.168.111.0 mask 255.255.255.0 192.168.22.2
PC2
          0.0.0.0          0.0.0.0    192.168.111.1  192.168.111.105     25
PC3
          0.0.0.0          0.0.0.0    192.168.111.1  192.168.111.101     25
PC1
route -p add 192.168.111.0 mask 255.255.255.0 192.168.22.2
Active Routes:
          0.0.0.0          0.0.0.0      192.168.8.1   192.168.8.101       9
        127.0.0.0        255.0.0.0        127.0.0.1       127.0.0.1       1
      192.168.8.0    255.255.255.0    192.168.8.101   192.168.8.101       9
    192.168.8.101  255.255.255.255        127.0.0.1       127.0.0.1       9
    192.168.8.255  255.255.255.255    192.168.8.101   192.168.8.101       9
     192.168.22.0    255.255.255.0    192.168.22.11   192.168.22.11       1
    192.168.22.11  255.255.255.255        127.0.0.1       127.0.0.1       1
   192.168.22.255  255.255.255.255    192.168.22.11   192.168.22.11       1
    192.168.111.0    255.255.255.0     192.168.22.2   192.168.22.11       1
ping 192.168.111.105
Pinging 192.168.111.105 with 32 bytes of data:
Reply from 192.168.111.105: bytes=32 time=166ms TTL=127
Reply from 192.168.111.105: bytes=32 time=61ms TTL=127
Reply from 192.168.111.105: bytes=32 time=86ms TTL=127
ping 192.168.111.101
Pinging 192.168.111.101 with 32 bytes of data:
Reply from 192.168.111.101: bytes=32 time=98ms TTL=127
Reply from 192.168.111.101: bytes=32 time=90ms TTL=127
Reply from 192.168.111.101: bytes=32 time=541ms TTL=127
Reply from 192.168.111.101: bytes=32 time=105ms TTL=127
It's not trivial but if you insist on OpenVPN client then this is the way to go.
valant98
Post by valant98 » Fri Mar 31, 2023 7:24 am
Thanks a lot for the reply, this was the solution for me. Cheers!
