Silent Install
cramaboule
Silent Install
Post by cramaboule » Tue Mar 28, 2023 1:30 pm
Hello all,
As many people requested a silent install, I made with AutoIt an almost silent install.
The script will install the client, turn it into easy mode and import the vpn settings.
I posted my AutoIt Script here https://github.com/cramaboule/Silent-In ... her-Client
Feel free to modify it, and compile it !
Enjoy,
C.
Re: Silent Install
Post by solo » Wed Mar 29, 2023 3:05 am
While more chatty, it already exists.
Easy Installer Creator is a tool for enterprise administrators. You can create a VPN Client installer with embedding a specific VPN connection setting by using Easy Installer Creator. Personal users can also exploit this tool.
A created Easy Installer can be distributed to employees in the enterprise by using file servers or e-mails. If a user runs the Easy Installer, VPN Client will be installed and the VPN connection setting will be imported, and then the VPN connection will be started automatically.
In Start menu, or "C:\Program Files\SoftEther VPN Client\vpnsetup.exe" /easy:true
cramaboule
Re: Silent Install
Post by cramaboule » Wed Mar 29, 2023 10:56 am
Nice, i didn't know !
C.
