Hi
I have a question: when we have more than one hub in the softether server, which hub does answer to OPENVPN client connection?
actually i'm looking for a method to assign different IPs to OPENVPN clients, based on the username, or based on TCP port, or somthing else. is this possible?
The Hub supporting OPENVPN request
Re: The Hub supporting OPENVPN request
If there are two or more Virtual HUBs on the VPN Server, you have to specify the username as:
"Username@Virtual-HUB-Name"
or:
"Virtual-HUB-Name\Username"
https://www.softether.org/5-download/historyVirtual MAC address reservation
When the user object is using the standard user authentication, you need to write the arbitrary virtual MAC address on the "Note" field on the user object. For example, the "Note" field will have the MAC address format which starts with "MAC:" followed by a 6-bytes ASCII-encoded HEX string, such like "MAC:ae:00:00:00:00:01". We recommend to use the "ae" on the first byte of the MAC address...
hainsoft
Thank you very much
It works
Now I can present different IP ranges for users on one VPN server, only by using different HUBs, then the user can connect to different server farms only by adding @ and HUB name in this username field in OPENVPN client software.
It works
