Hi
Need simple solution that connect to vpn on pc1 then share that connection with other pcs located on lan.
Any idea?
FYI: pc1 is a minimal linux server (has soft ether)
Other pcs are windows and linux, and i prefer to give them ip/port pc1 and set it as proxy, instead of install any other client app.
Any idea?
Thanks,
Share vpn connection for lan pcs as proxy server
indeed_1
