Hello everyone,
I just started using Softether and followed the tutorial configuration to complete single point connection availability.
Now I want to connect two different networks through Softether. Through the application, I can obtain the private IP addresses of both networks, but I cannot make both networks interconnected. Could you please ask who can help me,Thanks!
The main branch Node1 configuration is 172.16.2.0/24 using VPN server;
Configure from branch node2 to 10.10.25.0/24 using bridge;
In the session management interface, you can see the IP information on both ends. Through tracert, you can only track routes to single gateway nodes。
LAN to LAN connection failed
wuxiaoliang
wuxiaoliang
Re: LAN to LAN connection failed
The reference documents in the link also failed to connect me to the networks of the two LANs.
