Intune - Softether client deployment
ew27192
Post by ew27192 » Wed May 31, 2023 11:01 am
Has anyone deployed the Windows Softether client using Intune before? I'm trying to find a working silent install command. Can anyone help?
Re: Intune - Softether client deployment
Post by solo » Wed May 31, 2023 11:36 am
There is no silent install option but you can prepare an easy install package.
Easy Installer Creator is a tool for enterprise administrators. You can create a VPN Client installer with embedding a specific VPN connection setting by using Easy Installer Creator. Personal users can also exploit this tool.
A created Easy Installer can be distributed to employees in the enterprise by using file servers or e-mails. If a user runs the Easy Installer, VPN Client will be installed and the VPN connection setting will be imported, and then the VPN connection will be started automatically.
Run: "C:\Program Files\SoftEther VPN Client\vpnsetup.exe" /easy:true
