Reconnecting to a cascading connection on Softether VPN Server
Barton
Hi. I saw in this topic https://www.vpnusers.com/viewtopic.php?t=67587 manual for switching for Softether VPN Client. I have a Softether VPN Server installed and would also like to reconnect at a certain time. I need to switch to a cascade connection. Please help me how to implement this?
Re: Reconnecting to a cascading connection on Softether VPN Server
6.4.48 "CascadeOnline": Switch Cascade Connection to Online Status
Command Name CascadeOnline
Purpose Switch Cascade Connection to Online Status
Description When a Cascade Connection registered on the currently managed Virtual Hub is specified, use this to switch that Cascade Connection to online status. The Cascade Connection that is switched to online status begins the process of connecting to the destination VPN Server in accordance with the Connection Setting. The Cascade Connection that is switched to online status will establish normal connection to the VPN Server or continue to attempt connection until it is switched to offline status.
You cannot execute this command for Virtual Hubs of VPN Servers operating as a cluster.
Command-line CascadeOnline [name]
Arguments for "CascadeOnline":
name Specify the name of the Cascade Connection to switch to online status.
6.4.49 "CascadeOffline": Switch Cascade Connection to Offline Status
Command Name CascadeOffline
Purpose Switch Cascade Connection to Offline Status
Description When a Cascade Connection registered on the currently managed Virtual Hub is specified, use this to switch that Cascade Connection to offline status. The Cascade Connection that is switched to offline will not connect to the VPN Server until next time it is switched to the online status using the CascadeOnline command
Command-line CascadeOffline [name]
Arguments for "CascadeOffline":
name Specify the name of the Cascade Connection to switch to offline status.
Barton
Thanks! Please help me with the syntax, this option does not work,
vpncmd 127.0.0.1:5555 /SERVER /adminhub:VPN /PASSWORD:MYPASSWORD /CMD:CascadeOffline connectname CascadeOnline connectname
Only one thing works, for example:
CascadeOnline ignored. I tried with /IN anyway, 2 commands in a row are not executed.
Thanks!
Thanks!
Works for me...
C:\Program Files\SoftEther VPN Server>vpncmd localhost:5555 /server /password:9999 /adminhub:VPN /cmd CascadeOffline test
vpncmd command - SoftEther VPN Command Line Management Utility
SoftEther VPN Command Line Management Utility (vpncmd command)
Version 4.41 Build 9787 (English)
Compiled 2023/03/14 11:00:03 by buildsan at crosswin with OpenSSL 3.0.7
Copyright (c) 2012-2023 SoftEther VPN Project. All Rights Reserved.
Connection has been established with VPN Server "localhost" (port 5555).
You have administrator privileges for the entire VPN Server.
The Virtual Hub "VPN" has been selected.
VPN Server/VPN>CascadeOffline test
CascadeOffline command - Switch Cascade Connection to Offline Status
C:\Program Files\SoftEther VPN Server>vpncmd localhost:5555 /server /password:9999 /adminhub:VPN /cmd CascadeOnline test
VPN Server/VPN>CascadeOnline test
CascadeOnline command - Switch Cascade Connection to Online Status
The command completed successfully.-
Barton
So it also works for me, how do I transfer the connection offline and then online in one line? Like this:
Does not work.
Does not work.
Easy, run "transfer-the-connection-offline-and-then-online-in-one-line.bat"
@echo off
path=%path%;C:\Program Files\SoftEther VPN Server
ping -n 3 127.0.0.1 >nul
Barton
Thank you so much for your help!
