Hello, All of the Senior
Good day to you.
Can I make a static route table push in the SoftEther OpenSource Version? I have 5 VPS servers in the cloud. I will install VPN server into one of the VPS servers and I will disable SSH login with the Public IP. When someone wants to log in to the VPS server, they must connect to the VPN client and log in with a Private IP. Previously I installed the Softether VPN server on a Windows server and that is OK. Now, I want to change to Ubuntu Server, the static route table push function is not supported.
Public IP = 150.95.x.x
Privat IP = 172.30.40.0/24
VPN client release IP = 192.168.30.0/24
Please help and support to me Sirs.
How to set static routing table to push function in OpenSource Version
saiandrew
Re: How to set static routing table to push function in OpenSource Version
On your clients add persistent static routes to the 172.30.40.0/24 subnet.
saiandrew
How can I do that about it? Sir. >> On your clients add persistent static routes to the 172.30.40.0/24 subnet.
