Issue on DHCP
TheyDontKnowMeSon
Issue on DHCP
Post by TheyDontKnowMeSon » Thu Nov 16, 2023 9:54 pm
Hi together,
i currently run Softether on a pi which is connected via eth0 to my fritzbox. The ports i am currently forwarding are TCP&UDP 443 and UDP 67-68
If i start the connection on my laptop to the pi, i am able to connect to the hub, but as soon as the waiting for dhcp window comes i lose connection. I literally tried every setting i could think of, bridged eth0, SecureNat - enabled Virtual NAT, Secure Nat - disabled Virtual NAT, disabled bridge &SecureNat, enabled bridge and SecureNat at the same time.
My network setup is as following :
fritzbox : 10.25.25.1
pi : 10.25.25.150
For the SecureNat config i have folling ip's :
Virtual Hosts Network Interface Settings - 192.168.30.1/255.255.255.0
DHCP Functions : 192.168.30.10 to 192.168.39.200/255.255.255.0
And the Client Settings are
Default Gateway : 10.25.25.1 (changed this to all i could think of, even my public ip)
Dns 10.25.25.150 (am running pihole aswell here)
alt DNS : 8.8.8.8
DomainName fritz.box
Im rly at loss what else i could try. Thank you guys in advance
BR
Re: Issue on DHCP
Post by solo » Fri Nov 17, 2023 1:11 am
You have created a network loop. Test out the client from another ISP.
TheyDontKnowMeSon
Re: Issue on DHCP
Post by TheyDontKnowMeSon » Fri Nov 17, 2023 9:02 am
I tried from LTE and its not working :/
Re: Issue on DHCP
Post by solo » Fri Nov 17, 2023 9:13 am
So on LTE... "as soon as the waiting for dhcp window comes i lose connection", yes?
TheyDontKnowMeSon
Re: Issue on DHCP
Post by TheyDontKnowMeSon » Fri Nov 17, 2023 9:15 am
Yes, correct
Re: Issue on DHCP
Post by solo » Fri Nov 17, 2023 9:30 am
Assuming default settings:
- on the SE hub set: Log Save Setting / Save Packet Log: ON / ICMP Packet: Header Only
- briefly disable the server's firewall
- make a [LTE] VPN connection
- post as code SE's packet_log from around the client's connection timeframe
Also, post as code from VPN client after the failed connection:
netstat -r
ipconfig /all
TheyDontKnowMeSon
Re: Issue on DHCP
Post by TheyDontKnowMeSon » Fri Nov 17, 2023 3:31 pm
I also have issues where vpncmd or the gui application dont save my configuration. The only reliable way for me to have persistent changes is by flushing in vpncmd after every change :(
PacketLog :
2023-11-17,16:19:04.111,SID-TEST-2,-,5EE2C08408F6,FFFFFFFFFFFF,0x0800,342,DHCPv4,Request,0.0.0.0,bootpc(68),255.255.255.255,bootps(67),-,-,TransactionId=1010675691 ClientIP=0.0.0.0 YourIP=0.0.0.0 ServerIP=0.0.0.0 RelayIP=0.0.0.0,-,46.114.227.227,-
2023-11-17,16:19:20.950,SID-TEST-2,-,5EE2C08408F6,FFFFFFFFFFFF,0x0800,342,DHCPv4,Request,0.0.0.0,bootpc(68),255.255.255.255,bootps(67),-,-,TransactionId=2712054057 ClientIP=0.0.0.0 YourIP=0.0.0.0 ServerIP=0.0.0.0 RelayIP=0.0.0.0,-,46.114.227.227,-
2023-11-17,16:22:35.399,SID-TEST-2,-,5EE2C08408F6,FFFFFFFFFFFF,0x0800,342,DHCPv4,Request,0.0.0.0,bootpc(68),255.255.255.255,bootps(67),-,-,TransactionId=2514088894 ClientIP=0.0.0.0 YourIP=0.0.0.0 ServerIP=0.0.0.0 RelayIP=0.0.0.0,-,46.114.227.227,-
Ipconfig : (removed inactive connections)
Windows-IP-Konfiguration
   Hostname  . . . . . . . . . . . . : XXXX
   Prim„res DNS-Suffix . . . . . . . : XXXX
   Knotentyp . . . . . . . . . . . . : Hybrid
   IP-Routing aktiviert  . . . . . . : Nein
   WINS-Proxy aktiviert  . . . . . . : Nein
   DNS-Suffixsuchliste . . . . . . . : XXXX
Ethernet-Adapter vEthernet (WLAN):
   Verbindungsspezifisches DNS-Suffix:
   Beschreibung. . . . . . . . . . . : Hyper-V Virtual Ethernet Adapter #6
   Physische Adresse . . . . . . . . : 00-15-5D-8D-DF-4F
   DHCP aktiviert. . . . . . . . . . : Nein
   Autokonfiguration aktiviert . . . : Ja
   Verbindungslokale IPv6-Adresse  . : fe80::726d:3caf:1c1a:15d6%88(Bevorzugt)
   IPv4-Adresse  . . . . . . . . . . : 172.23.16.1(Bevorzugt)
   Subnetzmaske  . . . . . . . . . . : 255.255.240.0
   Standardgateway . . . . . . . . . :
   DHCPv6-IAID . . . . . . . . . . . : 1476400477
   DHCPv6-Client-DUID. . . . . . . . : 00-01-00-01-28-5A-88-B6-90-2E-16-26-E4-28
   DNS-Server  . . . . . . . . . . . : fec0:0:0:ffff::1%1
                                       fec0:0:0:ffff::2%1
                                       fec0:0:0:ffff::3%1
   NetBIOS ber TCP/IP . . . . . . . : Aktiviert
Ethernet-Adapter VirtualBox Host-Only Network:
   Beschreibung. . . . . . . . . . . : VirtualBox Host-Only Ethernet Adapter
   Physische Adresse . . . . . . . . : 0A-00-27-00-00-08
   Verbindungslokale IPv6-Adresse  . : fe80::8b4:ee80:789:bc3b%8(Bevorzugt)
   IPv4-Adresse  . . . . . . . . . . : 192.168.56.1(Bevorzugt)
   Subnetzmaske  . . . . . . . . . . : 255.255.255.0
   DHCPv6-IAID . . . . . . . . . . . : 722075687
                                       fec0:0:0:ffff::2%1
                                       fec0:0:0:ffff::3%1
Drahtlos-LAN-Adapter LAN-Verbindung* 1:
   Medienstatus. . . . . . . . . . . : Medium getrennt
   Beschreibung. . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
   Physische Adresse . . . . . . . . : 76-4C-A1-DC-EE-29
   DHCP aktiviert. . . . . . . . . . : Ja
Drahtlos-LAN-Adapter LAN-Verbindung* 2:
   Beschreibung. . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #2
   Physische Adresse . . . . . . . . : F6-4C-A1-DC-EE-29
Ethernet-Adapter VMware Network Adapter VMnet1:
   Beschreibung. . . . . . . . . . . : VMware Virtual Ethernet Adapter for VMnet1
   Physische Adresse . . . . . . . . : 00-50-56-C0-00-01
   Verbindungslokale IPv6-Adresse  . : fe80::68c5:e936:4f5:a358%15(Bevorzugt)
   IPv4-Adresse  . . . . . . . . . . : 192.168.222.1(Bevorzugt)
   DHCPv6-IAID . . . . . . . . . . . : 83906646
                                       fec0:0:0:ffff::2%1
                                       fec0:0:0:ffff::3%1
Ethernet-Adapter VMware Network Adapter VMnet8:
   Beschreibung. . . . . . . . . . . : VMware Virtual Ethernet Adapter for VMnet8
   Physische Adresse . . . . . . . . : 00-50-56-C0-00-08
   Verbindungslokale IPv6-Adresse  . : fe80::23ad:66d1:2689:53de%16(Bevorzugt)
   IPv4-Adresse  . . . . . . . . . . : 192.168.10.1(Bevorzugt)
   DHCPv6-IAID . . . . . . . . . . . : 184569942
                                       fec0:0:0:ffff::2%1
                                       fec0:0:0:ffff::3%1
Drahtlos-LAN-Adapter WLAN:
   Beschreibung. . . . . . . . . . . : Realtek RTL8852AE WiFi 6 802.11ax PCIe Adapter
   Physische Adresse . . . . . . . . : 74-4C-A1-DC-EE-29
   IPv6-Adresse. . . . . . . . . . . : 2a02:3037:214:4eea:f884:90b1:2d1a:c1ce(Bevorzugt)
   Tempor„re IPv6-Adresse. . . . . . : 2a02:3037:214:4eea:d183:ba9a:59a7:1ea0(Bevorzugt)
   Verbindungslokale IPv6-Adresse  . : fe80::74d4:7576:f8c1:c59c%19(Bevorzugt)
   IPv4-Adresse  . . . . . . . . . . : 172.20.10.10(Bevorzugt)
   Subnetzmaske  . . . . . . . . . . : 255.255.255.240
   Lease erhalten. . . . . . . . . . : Freitag, 17. November 2023 15:58:37
   Lease l„uft ab. . . . . . . . . . : Samstag, 18. November 2023 15:58:39
   Standardgateway . . . . . . . . . : fe80::3057:14ff:fe4d:8b64%19
                                       172.20.10.1
   DHCP-Server . . . . . . . . . . . : 172.20.10.1
   DHCPv6-IAID . . . . . . . . . . . : 108285089
   DNS-Server  . . . . . . . . . . . : fe80::3057:14ff:fe4d:8b64%19
                                       172.20.10.1
Ethernet-Adapter vEthernet (LAN):
   Physische Adresse . . . . . . . . : 00-15-5D-59-D4-2F
   Verbindungslokale IPv6-Adresse  . : fe80::92c9:95fb:4e12:e7be%13(Bevorzugt)
   IPv4-Adresse  . . . . . . . . . . : 172.24.80.1(Bevorzugt)
   DHCPv6-IAID . . . . . . . . . . . : 218109277
                                       fec0:0:0:ffff::2%1
                                       fec0:0:0:ffff::3%1
Ethernet-Adapter vEthernet (VMware Network ):
   Beschreibung. . . . . . . . . . . : Hyper-V Virtual Ethernet Adapter #2
   Physische Adresse . . . . . . . . : 00-15-5D-C0-11-7F
   Verbindungslokale IPv6-Adresse  . : fe80::cb57:df54:8610:75e5%45(Bevorzugt)
   IPv4-Adresse  . . . . . . . . . . : 172.22.48.1(Bevorzugt)
   DHCPv6-IAID . . . . . . . . . . . : 754980189
                                       fec0:0:0:ffff::2%1
                                       fec0:0:0:ffff::3%1
Ethernet-Adapter vEthernet (VMware Network ) 2:
   Beschreibung. . . . . . . . . . . : Hyper-V Virtual Ethernet Adapter #3
   Physische Adresse . . . . . . . . : 00-15-5D-99-A0-55
   Verbindungslokale IPv6-Adresse  . : fe80::3a8f:4d0e:fa8b:5ad3%50(Bevorzugt)
   IPv4-Adresse  . . . . . . . . . . : 172.21.240.1(Bevorzugt)
   DHCPv6-IAID . . . . . . . . . . . : 838866269
                                       fec0:0:0:ffff::2%1
                                       fec0:0:0:ffff::3%1
Ethernet-Adapter vEthernet (VirtualBox Host):
   Beschreibung. . . . . . . . . . . : Hyper-V Virtual Ethernet Adapter #4
   Physische Adresse . . . . . . . . : 00-15-5D-79-4B-BB
   Verbindungslokale IPv6-Adresse  . : fe80::1e4f:273:fb3b:2790%55(Bevorzugt)
   IPv4-Adresse  . . . . . . . . . . : 172.29.32.1(Bevorzugt)
   DHCPv6-IAID . . . . . . . . . . . : 922752349
                                       fec0:0:0:ffff::2%1
                                       fec0:0:0:ffff::3%1
Ethernet-Adapter vEthernet (Ethernet 2):
   Beschreibung. . . . . . . . . . . : Hyper-V Virtual Ethernet Adapter #5
   Physische Adresse . . . . . . . . : 00-15-5D-A8-45-27
   Verbindungslokale IPv6-Adresse  . : fe80::8387:e816:f6fd:e3c6%83(Bevorzugt)
   IPv4-Adresse  . . . . . . . . . . : 172.21.144.1(Bevorzugt)
   DHCPv6-IAID . . . . . . . . . . . : 1392514397
                                       fec0:0:0:ffff::2%1
                                       fec0:0:0:ffff::3%1
Netstat :
Schnittstellenliste
 23...5e e2 c0 84 08 f6 ......VPN Client Adapter - VPN
 28...00 ff d7 b4 43 c6 ......TAP-Windows Adapter V9 for OpenVPN Connect
 30...90 2e 16 26 e4 28 ......Intel(R) Ethernet Connection (13) I219-V
 12...80 6d 97 19 3e f7 ......Lenovo USB Ethernet
 88...00 15 5d 8d df 4f ......Hyper-V Virtual Ethernet Adapter #6
  8...0a 00 27 00 00 08 ......VirtualBox Host-Only Ethernet Adapter
  4...76 4c a1 dc ee 29 ......Microsoft Wi-Fi Direct Virtual Adapter
 18...f6 4c a1 dc ee 29 ......Microsoft Wi-Fi Direct Virtual Adapter #2
 15...00 50 56 c0 00 01 ......VMware Virtual Ethernet Adapter for VMnet1
 16...00 50 56 c0 00 08 ......VMware Virtual Ethernet Adapter for VMnet8
 19...74 4c a1 dc ee 29 ......Realtek RTL8852AE WiFi 6 802.11ax PCIe Adapter
 13...00 15 5d 59 d4 2f ......Hyper-V Virtual Ethernet Adapter
 45...00 15 5d c0 11 7f ......Hyper-V Virtual Ethernet Adapter #2
 50...00 15 5d 99 a0 55 ......Hyper-V Virtual Ethernet Adapter #3
 55...00 15 5d 79 4b bb ......Hyper-V Virtual Ethernet Adapter #4
 83...00 15 5d a8 45 27 ......Hyper-V Virtual Ethernet Adapter #5
IPv4-Routentabelle
Aktive Routen:
     Netzwerkziel    Netzwerkmaske          Gateway    Schnittstelle Metrik
          0.0.0.0          0.0.0.0      172.20.10.1     172.20.10.10     50
        127.0.0.0        255.0.0.0   Auf Verbindung         127.0.0.1    331
        127.0.0.1  255.255.255.255   Auf Verbindung         127.0.0.1    331
  127.255.255.255  255.255.255.255   Auf Verbindung         127.0.0.1    331
    130.158.6.108  255.255.255.255      172.20.10.1     172.20.10.10     50
      169.254.0.0      255.255.0.0   Auf Verbindung   169.254.122.135    257
  169.254.122.135  255.255.255.255   Auf Verbindung   169.254.122.135    257
  169.254.255.255  255.255.255.255   Auf Verbindung   169.254.122.135    257
      172.20.10.0  255.255.255.240   Auf Verbindung      172.20.10.10    306
     172.20.10.10  255.255.255.255   Auf Verbindung      172.20.10.10    306
     172.20.10.15  255.255.255.255   Auf Verbindung      172.20.10.10    306
     172.21.144.0    255.255.240.0   Auf Verbindung      172.21.144.1   5256
     172.21.144.1  255.255.255.255   Auf Verbindung      172.21.144.1   5256
   172.21.159.255  255.255.255.255   Auf Verbindung      172.21.144.1   5256
     172.21.240.0    255.255.240.0   Auf Verbindung      172.21.240.1   5256
     172.21.240.1  255.255.255.255   Auf Verbindung      172.21.240.1   5256
   172.21.255.255  255.255.255.255   Auf Verbindung      172.21.240.1   5256
      172.22.48.0    255.255.240.0   Auf Verbindung       172.22.48.1   5256
      172.22.48.1  255.255.255.255   Auf Verbindung       172.22.48.1   5256
    172.22.63.255  255.255.255.255   Auf Verbindung       172.22.48.1   5256
      172.23.16.0    255.255.240.0   Auf Verbindung       172.23.16.1    271
      172.23.16.1  255.255.255.255   Auf Verbindung       172.23.16.1    271
    172.23.31.255  255.255.255.255   Auf Verbindung       172.23.16.1    271
      172.24.80.0    255.255.240.0   Auf Verbindung       172.24.80.1   5256
      172.24.80.1  255.255.255.255   Auf Verbindung       172.24.80.1   5256
    172.24.95.255  255.255.255.255   Auf Verbindung       172.24.80.1   5256
      172.29.32.0    255.255.240.0   Auf Verbindung       172.29.32.1   5256
      172.29.32.1  255.255.255.255   Auf Verbindung       172.29.32.1   5256
    172.29.47.255  255.255.255.255   Auf Verbindung       172.29.32.1   5256
     192.168.10.0    255.255.255.0   Auf Verbindung      192.168.10.1    291
     192.168.10.1  255.255.255.255   Auf Verbindung      192.168.10.1    291
   192.168.10.255  255.255.255.255   Auf Verbindung      192.168.10.1    291
     192.168.56.0    255.255.255.0   Auf Verbindung      192.168.56.1    281
     192.168.56.1  255.255.255.255   Auf Verbindung      192.168.56.1    281
   192.168.56.255  255.255.255.255   Auf Verbindung      192.168.56.1    281
    192.168.222.0    255.255.255.0   Auf Verbindung     192.168.222.1    291
    192.168.222.1  255.255.255.255   Auf Verbindung     192.168.222.1    291
  192.168.222.255  255.255.255.255   Auf Verbindung     192.168.222.1    291
  217.254.241.173  255.255.255.255      172.20.10.1     172.20.10.10     50
        224.0.0.0        240.0.0.0   Auf Verbindung         127.0.0.1    331
        224.0.0.0        240.0.0.0   Auf Verbindung      192.168.56.1    281
        224.0.0.0        240.0.0.0   Auf Verbindung   169.254.122.135    257
        224.0.0.0        240.0.0.0   Auf Verbindung     192.168.222.1    291
        224.0.0.0        240.0.0.0   Auf Verbindung      192.168.10.1    291
        224.0.0.0        240.0.0.0   Auf Verbindung      172.20.10.10    306
        224.0.0.0        240.0.0.0   Auf Verbindung       172.24.80.1   5256
        224.0.0.0        240.0.0.0   Auf Verbindung       172.22.48.1   5256
        224.0.0.0        240.0.0.0   Auf Verbindung      172.21.240.1   5256
        224.0.0.0        240.0.0.0   Auf Verbindung       172.29.32.1   5256
        224.0.0.0        240.0.0.0   Auf Verbindung      172.21.144.1   5256
        224.0.0.0        240.0.0.0   Auf Verbindung       172.23.16.1    271
  255.255.255.255  255.255.255.255   Auf Verbindung         127.0.0.1    331
  255.255.255.255  255.255.255.255   Auf Verbindung      192.168.56.1    281
  255.255.255.255  255.255.255.255   Auf Verbindung   169.254.122.135    257
  255.255.255.255  255.255.255.255   Auf Verbindung     192.168.222.1    291
  255.255.255.255  255.255.255.255   Auf Verbindung      192.168.10.1    291
  255.255.255.255  255.255.255.255   Auf Verbindung      172.20.10.10    306
  255.255.255.255  255.255.255.255   Auf Verbindung       172.24.80.1   5256
  255.255.255.255  255.255.255.255   Auf Verbindung       172.22.48.1   5256
  255.255.255.255  255.255.255.255   Auf Verbindung      172.21.240.1   5256
  255.255.255.255  255.255.255.255   Auf Verbindung       172.29.32.1   5256
  255.255.255.255  255.255.255.255   Auf Verbindung      172.21.144.1   5256
  255.255.255.255  255.255.255.255   Auf Verbindung       172.23.16.1    271
St ndige Routen:
  Keine
IPv6-Routentabelle
Aktive Routen:
 If Metrik Netzwerkziel             Gateway
 19    306 ::/0                     fe80::3057:14ff:fe4d:8b64
  1    331 ::1/128                  Auf Verbindung
 19    306 2a02:3037:214:4eea::/64  Auf Verbindung
 19    306 2a02:3037:214:4eea:d183:ba9a:59a7:1ea0/128
                                    Auf Verbindung
 19    306 2a02:3037:214:4eea:f884:90b1:2d1a:c1ce/128
                                    Auf Verbindung
  8    281 fe80::/64                Auf Verbindung
 23    291 fe80::/64                Auf Verbindung
 15    291 fe80::/64                Auf Verbindung
 16    291 fe80::/64                Auf Verbindung
 19    306 fe80::/64                Auf Verbindung
 13   5256 fe80::/64                Auf Verbindung
 45   5256 fe80::/64                Auf Verbindung
 50   5256 fe80::/64                Auf Verbindung
 55   5256 fe80::/64                Auf Verbindung
 83   5256 fe80::/64                Auf Verbindung
 88    271 fe80::/64                Auf Verbindung
  8    281 fe80::8b4:ee80:789:bc3b/128
                                    Auf Verbindung
 55   5256 fe80::1e4f:273:fb3b:2790/128
                                    Auf Verbindung
 16    291 fe80::23ad:66d1:2689:53de/128
                                    Auf Verbindung
 50   5256 fe80::3a8f:4d0e:fa8b:5ad3/128
                                    Auf Verbindung
 15    291 fe80::68c5:e936:4f5:a358/128
                                    Auf Verbindung
 88    271 fe80::726d:3caf:1c1a:15d6/128
                                    Auf Verbindung
 19    306 fe80::74d4:7576:f8c1:c59c/128
                                    Auf Verbindung
 83   5256 fe80::8387:e816:f6fd:e3c6/128
                                    Auf Verbindung
 13   5256 fe80::92c9:95fb:4e12:e7be/128
                                    Auf Verbindung
 23    291 fe80::af77:d28d:e815:1ae3/128
                                    Auf Verbindung
 45   5256 fe80::cb57:df54:8610:75e5/128
                                    Auf Verbindung
  1    331 ff00::/8                 Auf Verbindung
  8    281 ff00::/8                 Auf Verbindung
 23    291 ff00::/8                 Auf Verbindung
 15    291 ff00::/8                 Auf Verbindung
 16    291 ff00::/8                 Auf Verbindung
 19    306 ff00::/8                 Auf Verbindung
 13   5256 ff00::/8                 Auf Verbindung
 45   5256 ff00::/8                 Auf Verbindung
 50   5256 ff00::/8                 Auf Verbindung
 55   5256 ff00::/8                 Auf Verbindung
 83   5256 ff00::/8                 Auf Verbindung
 88    271 ff00::/8                 Auf Verbindung
St ndige Routen:
  Keine
Re: Issue on DHCP
Post by solo » Fri Nov 17, 2023 10:55 pm
2023-11-17,16:19:04.111,SID-TEST-2,-,5EE2C08408F6,FFFFFFFFFFFF,0x0800,342,DHCPv4,Request,...
There are only DHCPv4 Requests and no Response. That pi/fritzbox has dysfunctional or nonexistent DHCP server. As it appears to be a small network just apply static IPs and you're good to go.
TheyDontKnowMeSon
Re: Issue on DHCP
Post by TheyDontKnowMeSon » Sat Nov 18, 2023 11:49 am
With local bridge i get this
2023-11-18,12:41:33.791,SID-LOCALBRIDGE-2,-,E45F0134754F,40623107BD09,0x0800,74,TCP_CONNECTv4,SYN+ACK,10.25.25.150,domain(53),10.25.25.188,39190,1333844117,4175997184,WindowSize=65160,-,-,-
2023-11-18,12:50:34.047,SID-LOCALBRIDGE-1,-,0857FBD630DB,E45F0134754F,0x0800,90,DNSv4,DNS_Query,10.25.25.33,20322,10.25.25.189,domain(53),-,-,device-messaging-na.amazon.com,-,-,-
Also my Hub now switches to offline after trying to connect
Re: Issue on DHCP
Post by solo » Sat Nov 18, 2023 12:04 pm
Aim to get this:
...DHCPv4,Response,192.168.30.1,bootps(67),255.255.255.255,bootpc(68),-,-,TransactionId=7912098 ClientIP=0.0.0.0 YourIP=192.168.30.10 ServerIP=192.168.30.1 RelayIP=0.0.0.0,-,-,-
