SoftEther speed is 10% of max speed
shakibamoshiri
Post by shakibamoshiri » Fri Jan 12, 2024 10:54 pm
Running some tests with "vpncmd /tools /cmd trafficserver/trafficclient" shows big differences between non-tunnel throughput with tunnel throughput.
- enable/disable "UDP acceleration" did not make any difference
- enable/disable "Encrypt VPN sessions" did not make any difference
- using 32 TCP connections in parallel did not make such a difference
- using SE tap interface or Linux veth interface did not make such a difference
- SeucreNAT never enabled
- no other application were using the bandwidth
Can someone tell why and where the bottlenecks are?
- does the ISP throttle tunnels ?
- does SE sever need a psychical machine and a dedicated NIC ?
- can bridging SE tap to NIC help ?
Raw ipv4 to ipv4
Item Name                                             |        Normal View|Simplified View
Time Span for Measurement                             |       00:00:15.003|
Data Correction for Ethernet Frames                   |                Yes|
Communication Data Volume in Download Direction       |1,499,874,592 Bytes|    1.50 GBytes
Communication Data Volume in Upload Direction         |4,136,123,567 Bytes|    4.14 GBytes
Total Communication Data Volume                       |5,635,998,159 Bytes|    5.64 GBytes
Relay Device Input Output Total Throughput Computation|                 No|
Average Throughput in Download Direction              |    799,773,161 bps|    799.77 Mbps
Average Throughput in Upload Direction                |  2,205,491,470 bps|      2.21 Gbps
Total Average Throughput                              |  3,005,264,631 bps|      3.01 Gbps
Raw ipv6 to ipv6
Time Span for Measurement                             |       00:00:15.005|
Communication Data Volume in Download Direction       |2,388,507,060 Bytes|    2.39 GBytes
Communication Data Volume in Upload Direction         |4,072,577,679 Bytes|    4.07 GBytes
Total Communication Data Volume                       |6,461,084,739 Bytes|    6.46 GBytes
Average Throughput in Download Direction              |  1,273,445,950 bps|      1.27 Gbps
Average Throughput in Upload Direction                |  2,171,317,656 bps|      2.17 Gbps
Total Average Throughput                              |  3,444,763,606 bps|      3.44 Gbps
SE tap to tap (ipv4 cascade connections of 32 TCP)
Time Span for Measurement                             |     00:00:15.159|
Communication Data Volume in Download Direction       |169,248,795 Bytes|  169.25 MBytes
Communication Data Volume in Upload Direction         |233,014,116 Bytes|  233.01 MBytes
Total Communication Data Volume                       |402,262,911 Bytes|  402.26 MBytes
Average Throughput in Download Direction              |   89,319,240 bps|     89.32 Mbps
Average Throughput in Upload Direction                |  122,970,705 bps|    122.97 Mbps
Total Average Throughput                              |  212,289,945 bps|    212.29 Mbps
SE tap to tap (ipv6 cascade connects of 32 TCP)
Time Span for Measurement                             |     00:00:15.333|
Communication Data Volume in Download Direction       |200,008,443 Bytes|  200.01 MBytes
Communication Data Volume in Upload Direction         |267,175,682 Bytes|  267.18 MBytes
Total Communication Data Volume                       |467,184,125 Bytes|  467.18 MBytes
Average Throughput in Download Direction              |  104,354,499 bps|    104.35 Mbps
Average Throughput in Upload Direction                |  139,399,038 bps|    139.40 Mbps
Total Average Throughput                              |  243,753,537 bps|    243.75 Mbps
SE veth to veth (ipv4 cascade connects of 32 TCP) + (TSO has been set to off)
Time Span for Measurement                             |     00:00:15.183|
Communication Data Volume in Download Direction       |124,057,116 Bytes|  124.06 MBytes
Communication Data Volume in Upload Direction         |233,918,082 Bytes|  233.92 MBytes
Total Communication Data Volume                       |357,975,198 Bytes|  357.98 MBytes
Average Throughput in Download Direction              |   65,366,326 bps|     65.37 Mbps
Average Throughput in Upload Direction                |  123,252,628 bps|    123.25 Mbps
Total Average Throughput                              |  188,618,954 bps|    188.62 Mbps
Re: SoftEther speed is 10% of max speed
Post by solo » Sat Jan 13, 2024 12:10 am
It is possible. Check client/server and SE/DE versions' speed entirely on a test LAN. Also apparently In latest version of SoftEther, SecureNAT is faster than tap in Linux.
shakibamoshiri
Post by shakibamoshiri » Sat Jan 13, 2024 6:44 am
I did lots of tests
All tests were run with Dev version
Also Client to Server tested , it was a little bit slower
These test were done using SE server to SE server via cascade connections
LAN testing is a good point, it was overlooked I will check LAN and SecureNAT (I noticed on GitHub there is a new release)
shakibamoshiri
Post by shakibamoshiri » Sat Jan 13, 2024 9:07 am
Here are tests on a stable ISP in which I am sure there is no throttling
Ping from server A (client) to server B (server)
ping -c4 a.b.c.d
PING a.b.c.d (a.b.c.d) 56(84) bytes of data.
64 bytes from a.b.c.d icmp_seq=1 ttl=56 time=0.301 ms
64 bytes from a.b.c.d: icmp_seq=2 ttl=56 time=0.412 ms
64 bytes from a.b.c.d: icmp_seq=3 ttl=56 time=0.386 ms
64 bytes from a.b.c.d: icmp_seq=4 ttl=56 time=0.424 ms
--- a.b.c.d ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3076ms
rtt min/avg/max/mdev = 0.301/0.380/0.424/0.048 ms
Raw ipv4 to ipv4
Time Span for Measurement                             |        00:00:15.008|
Communication Data Volume in Download Direction       | 8,480,177,852 Bytes|    8.48 GBytes
Communication Data Volume in Upload Direction         |14,838,490,721 Bytes|   14.84 GBytes
Total Communication Data Volume                       |23,318,668,573 Bytes|   23.32 GBytes
Average Throughput in Download Direction              |   4,520,350,667 bps|      4.52 Gbps
Average Throughput in Upload Direction                |   7,909,643,241 bps|      7.91 Gbps
Total Average Throughput                              |  12,429,993,908 bps|     12.43 Gbps
Raw ipv6 to ipv6
Communication Data Volume in Download Direction       |10,569,028,485 Bytes|   10.57 GBytes
Communication Data Volume in Upload Direction         |13,413,274,334 Bytes|   13.41 GBytes
Total Communication Data Volume                       |23,982,302,819 Bytes|   23.98 GBytes
Average Throughput in Download Direction              |   5,634,936,879 bps|      5.63 Gbps
Average Throughput in Upload Direction                |   7,151,362,523 bps|      7.15 Gbps
Total Average Throughput                              |  12,786,299,402 bps|     12.79 Gbps
SE (dev version) tap to tap (ipv4 - 32 TCP cascade connections)
Time Span for Measurement                             |       00:00:15.006|
Communication Data Volume in Download Direction       |  748,546,393 Bytes|  748.55 MBytes
Communication Data Volume in Upload Direction         |  951,867,999 Bytes|    0.95 GBytes
Total Communication Data Volume                       |1,700,414,392 Bytes|    1.70 GBytes
Average Throughput in Download Direction              |    399,065,116 bps|    399.07 Mbps
Average Throughput in Upload Direction                |    507,459,948 bps|    507.46 Mbps
Total Average Throughput                              |    906,525,064 bps|    906.53 Mbps
### Testing Secure NAT (vNAT) ###
Since I am using two servers and they are connected via a split tunnel from
server A to server B. For testing vNAT, SecureNAT was enabled on Server B and
on Server A a tap interface added to a Linux namespace in order to isolate
server A speed test (client).
Here is a speed-test on the main namespace of server A (client)
Retrieving speedtest.net server list...
Selecting best server based on ping...
Hosted by 23M GmbH (Frankfurt am Main) [143.90 km]: 5.812 ms
Testing download speed................................................................................
Download: 4531.18 Mbit/s
Testing upload speed......................................................................................................
Upload: 2400.48 Mbit/s
Here is a speed-test on "setest" namespace of server A (client)
### check the ips
ip -br a
lo               UNKNOWN        127.0.0.1/8 ::1/128
tap_spt          UNKNOWN        192.168.40.10/24 fe80::5cbd:e5ff:fe63:4331/64
### check the routes
default via 192.168.40.1 dev tap_spt
1.1.1.1 dev tap_spt scope link
8.8.8.8 dev tap_spt scope link
192.168.40.0/24 dev tap_spt proto kernel scope link src 192.168.40.10
### result
Hosted by FoxHost (Falkenstein) [3469.74 km]: 42.152 ms
Download: 595.86 Mbit/s
Upload: 302.91 Mbit/s
NOTEs
- both servers A and B compiled the latest release https://github.com/SoftEtherVPN/SoftEth ... /5.02.5181
- both servers are Debian 11 from the same ISP
- both servers OS configurations are alike
But results are the same, speed is around 10% of max speed!
Now my question is that is this by design for FREE version of SE server ?
I mean if speed for a free version has been limited or no ?
shakibamoshiri
Post by shakibamoshiri » Sat Jan 13, 2024 10:14 am
A test with OpenConnect from Server A (client) to Server B (server) in a linux namespace
### test
# ip netns exec octest curl -s https://raw.githubusercontent.com/sivel/speedtest-cli/master/speedtest.py | python3 -
Hosted by LWLcom GmbH (Frankfurt) [143.90 km]: 8.774 ms
Download: 3852.81 Mbit/s
Upload: 1954.71 Mbit/s
### and
Hosted by LWLcom GmbH (Frankfurt) [143.90 km]: 8.783 ms
Download: 2963.31 Mbit/s
Upload: 1866.58 Mbit/s
You can see this test results are close the actual raw speed (no tunnel)
Also
Test OpenConnect with SE vpncmd tools
OC tun to tun test
Time Span for Measurement                             |     00:00:15.004|
Communication Data Volume in Download Direction       |512,340,215 Bytes|  512.34 MBytes
Communication Data Volume in Upload Direction         |134,116,520 Bytes|  134.12 MBytes
Total Communication Data Volume                       |646,456,735 Bytes|  646.46 MBytes
Average Throughput in Download Direction              |  273,175,267 bps|    273.18 Mbps
Average Throughput in Upload Direction                |   71,509,741 bps|     71.51 Mbps
Total Average Throughput                              |  344,685,008 bps|    344.69 Mbps
the result is not the same
It also possible that maybe I am doing them wrong!
Post by solo » Sat Jan 13, 2024 10:32 am
It seems the official binaries have no limits but the published source code is indeed limited (in some aspects, not sure about speed). Which brings me to your "latest" 5181 build - I got 5345 half a year ago, and currently build 5369 is available here https://dev.azure.com/SoftEther-VPN/Sof ... _a=summary
2023-12-03T13:13:04.2683705Z ##[section]Starting: PublishBuildArtifacts
2023-12-03T13:13:04.2797622Z ==============================================================================
2023-12-03T13:13:04.2798223Z Task         : Publish build artifacts
2023-12-03T13:13:04.2798541Z Description  : Publish build artifacts to Azure Pipelines or a Windows file share
2023-12-03T13:13:04.2799078Z Version      : 1.231.0
2023-12-03T13:13:04.2799316Z Author       : Microsoft Corporation
2023-12-03T13:13:04.2799732Z Help         : https://docs.microsoft.com/azure/devops/pipelines/tasks/utility/publish-build-artifacts
2023-12-03T13:13:04.2800400Z ==============================================================================
2023-12-03T13:13:04.4914860Z ##[section]Async Command Start: Upload Artifact
2023-12-03T13:13:04.4915417Z Uploading 2 files
2023-12-03T13:13:09.6244902Z Uploading 'Installers/softether-vpnclient-5.02.5369.x64.exe' (12%)
2023-12-03T13:13:09.6246123Z Uploading 'Installers/softether-vpnclient-5.02.5369.x64.exe' (25%)
2023-12-03T13:13:09.6246864Z Uploading 'Installers/softether-vpnclient-5.02.5369.x64.exe' (37%)
2023-12-03T13:13:09.6247517Z Uploading 'Installers/softether-vpnclient-5.02.5369.x64.exe' (50%)
2023-12-03T13:13:09.6248197Z Uploading 'Installers/softether-vpnclient-5.02.5369.x64.exe' (62%)
2023-12-03T13:13:09.6248841Z Uploading 'Installers/softether-vpnclient-5.02.5369.x64.exe' (75%)
2023-12-03T13:13:09.6249479Z Uploading 'Installers/softether-vpnclient-5.02.5369.x64.exe' (87%)
2023-12-03T13:13:09.6250171Z Uploading 'Installers/softether-vpnserver_vpnbridge-5.02.5369.x64.exe' (11%)
2023-12-03T13:13:09.6250945Z Uploading 'Installers/softether-vpnserver_vpnbridge-5.02.5369.x64.exe' (22%)
2023-12-03T13:13:09.6251729Z Uploading 'Installers/softether-vpnserver_vpnbridge-5.02.5369.x64.exe' (33%)
2023-12-03T13:13:09.6252506Z Uploading 'Installers/softether-vpnserver_vpnbridge-5.02.5369.x64.exe' (44%)
2023-12-03T13:13:09.6253251Z Uploading 'Installers/softether-vpnserver_vpnbridge-5.02.5369.x64.exe' (55%)
2023-12-03T13:13:09.6254009Z Uploading 'Installers/softether-vpnserver_vpnbridge-5.02.5369.x64.exe' (66%)
2023-12-03T13:13:09.6254770Z Uploading 'Installers/softether-vpnserver_vpnbridge-5.02.5369.x64.exe' (77%)
2023-12-03T13:13:09.6255523Z Uploading 'Installers/softether-vpnserver_vpnbridge-5.02.5369.x64.exe' (88%)
2023-12-03T13:13:10.6387811Z File upload succeed.
2023-12-03T13:13:10.6388541Z Upload 'D:\a\1\a\installers' to file container: '#/25417882/Installers'
2023-12-03T13:13:10.6389307Z Associated artifact 3262 with build 1134
2023-12-03T13:13:10.6389771Z ##[section]Async Command End: Upload Artifact
2023-12-03T13:13:10.6390733Z ##[section]Finishing: PublishBuildArtifacts
shakibamoshiri
Post by shakibamoshiri » Sat Jan 13, 2024 12:49 pm
what do you mean by "official binary" ?
do mean stable version ? here
https://softether-download.com/files/so ... 8.31-tree/
several commits and changes tested (building from source) and result are the same.
shakibamoshiri
Post by shakibamoshiri » Sat Jan 13, 2024 8:03 pm
Here is the last commit on master branch
commit dc2b11918abe0566de69b7ae7bf5450cfbaa3b6d (HEAD -> master, tag: 5.02.5181, origin/master, origin/HEAD)
Merge: ff4b74af 7398bf27
Author: Ilya Shipitsin <chipitsine@gmail.com>
Date:   Sun Dec 3 14:08:34 2023 +0100
    Merge pull request #1933 from chipitsine/master
    CI: use OPENSSL_ROOT_DIR for cirrus-ci builds
you can see the commit message is "Merge pull request #1933 from chipitsine/master" and the same as the link you gave (the first one)
#20231203.1 • Merge pull request #1933 from chipitsine/master
and the master is tagged to "5.02.5181" so how could you get "5369" a year ago ?
Post by solo » Sun Jan 14, 2024 2:13 am
...so how could you get "5369" a year ago ?
No, I wrote that 5369 is available now.
This lack of attention may be affecting your speed testing methodology. Please test it out on this server -> speed.softether.com:9821
My results indicate no VPN upload speed degradation whatsoever and 40% lower download speed due to the connections asymmetry and other overheads.
shakibamoshiri
Post by shakibamoshiri » Sun Jan 14, 2024 8:38 am
First of all this link https://dev.azure.com/SoftEther-VPN/Sof ... _artifacts has no artifacts I cannot see any file to download
second this address is not available
This page isn’t workingspeed.softether.com sent an invalid response.
ERR_INVALID_HTTP_RESPONSE
Third how to test with speed.softether.com ?
Did you test on 1G and 10G networks ?
On slow networks like 10M or 100M it is okay the overload is low, but I am testing on 1G and 10G networks
One more question what is the best test methodology?
Post by solo » Sun Jan 14, 2024 9:47 am
Have a closer look AND click around. The original address again https://dev.azure.com/SoftEther-VPN/Sof ... _a=summary
vpncmd /tools /cmd TrafficClient speed.softether.com:9821
One that emulates real-life application:
- note TrafficClient from your VPN server to a speed server
- compare TrafficClient from a VPN client to the same speed server
shakibamoshiri
Post by shakibamoshiri » Sun Jan 14, 2024 1:17 pm
I think I have gotten blinded , cannot see any release binary files
This is measuring raw speed and I have no issue with this
VPN Tools>TrafficClient speed.softether.com:9821
TrafficClient command - Run Network Traffic Speed Test Tool in Client Mode
Starting the client program...
Network Traffic Speed Test Tool Client Setting Parameters
Destination Host Name               speed.softether.com
Destination TCP Port Number         9821
Number of TCP Connections to Establish 32
Data Transfer Direction             Full (Server < -- > Client)
Data Transmission Time              15.0 seconds
Data Correction for Ethernet Frames Yes
Measurement of Total Speed of Relay Device Input Output No
and the result
Time Span for Measurement                             |       00:00:15.007|
Communication Data Volume in Download Direction       |2,117,826,641 Bytes|    2.12 GBytes
Communication Data Volume in Upload Direction         |2,136,776,316 Bytes|    2.14 GBytes
Total Communication Data Volume                       |4,254,602,957 Bytes|    4.25 GBytes
Average Throughput in Download Direction              |  1,128,980,684 bps|      1.13 Gbps
Average Throughput in Upload Direction                |  1,139,082,463 bps|      1.14 Gbps
Total Average Throughput                              |  2,268,063,147 bps|      2.27 Gbps
The issue is the speed over a tunnel not over the internet
this is what I did , did you see my other posts ?
I used a Linux namespace to isolate it from main network
Anyway testing with a client is not that much hard I will do this as well
Post by solo » Mon Jan 15, 2024 1:00 am
Yeah, it wasn't a real-life application test. You did this...
Ping from server A (client) to server B (server)... time=0.301 ms
You had pushed that shared VPS to 100% CPU usage with multiple processes and several intra-connections. Since you can not test it directly from your [.ir] location and presumably don't control a separate VPS, I don't hold my breath for any conclusive result.
