Can I choose which apps go through the softether VPN tunnel?
ericshug
Post by ericshug » Sat Jul 27, 2024 12:10 am
How to set only chrome.exe through softether VPN?
Re: Can I choose which apps go through the softether VPN tunnel?
Post by solo » Sat Jul 27, 2024 7:08 am
Run it in a VM.
ericshug
Post by ericshug » Sun Jul 28, 2024 3:16 am
Run softether VPN tunnel in VM?
ericshug
Post by ericshug » Fri Aug 02, 2024 5:40 am
I really need to set a softether VPN tunnel for app,please help.
Post by solo » Fri Aug 02, 2024 7:10 am
If you don't have enough RAM for a VM, use something like Dante to create VPN-to-SOCKS interface for Chrome, or try How to make only a single program(game) go through VPN, but the rest ignore VPN and connect normally?
