VPN SERVER Microsoft Network Adapter Multiplexor Driver SMB ACCESS PROBLEM
badam1991
Post by badam1991 » Sat Aug 24, 2024 2:40 pm
DEAR SOFTETHERNET FANS
I HAVE ESTABLISHED A NIC CONNECTION ON MY MACHINE
SINCE I CAN'T ACCESS THE SAMBA MICROSOFT FILE SHARING SERVER I HAVE A VPN CONNECTION AND I GOT AN IP ADDRESS BUT THE FILE ACCESS STILL DOESN'T WORK
VPN SERV AND FILE SERV ARE THE SAME
\\BACKUP \\172.16.0.100 CAN BE ACCESSED ON MY MACHINE'S INTERNAL NETWORK BUT NOT FROM HOME PC REMOTE VPN SINCE THE NIC WAS CREATED
https://drive.google.com/file/d/1wSvvsL ... W_cDNz51dW
https://drive.google.com/file/d/1Or3Y9f ... NcKWpO4UuD
ENGLISH IS NOT MY STRENGTH SORRY
Re: VPN SERVER NIC SMB ACCESS PROBLEM
Post by solo » Sat Aug 24, 2024 3:57 pm
badam1991
Post by badam1991 » Mon Aug 26, 2024 6:33 pm
I tried it on another machine, as long as I connect 2 or 3 network cards to the machine, I connect them, after that the vpn is created, but samba does not work
merge Microsoft Network Adapter Multiplexor Driver
New-NetSwitchTeam -Name "NIC" -TeamMembers "Ethernet",Ethernet 2
no matter what I try, it doesn't work
it's just that I don't understand it enough
that's for sure
or just the routing is not configured well on the server
if I turn the client side of the server over, my home computer is the server and the work computer is the client instead of the server, but there is no home
Microsoft Network Adapter Multiplexer Driver network then
samba is available
if I turn on the Microsoft Network Adapter Multiplexer Driver for the vpn, nat is still not available for samba
I'm sure I don't understand, I can let it go
Post by solo » Mon Aug 26, 2024 10:52 pm
badam1991 wrote: ↑
Relax, it will work when you set DisableKernelModeSecureNAT = 1
badam1991
Post by badam1991 » Wed Aug 28, 2024 12:56 am
it works great and much faster thanks for your help and time
