I need to unbind DNS from IPV4 address
ql401375676
Post by ql401375676 » Sat Dec 21, 2024 4:43 am
Originally, I set up a dynamic DNS of “xxx.softether.net” and bound it to my IPV4 address. How should I cancel this binding? Now it has caused a lot of trouble to me. The original softether vpn server The server is no longer in use, how should I cancel this binding?
Re: I need to unbind DNS from IPV4 address
Post by solo » Sat Dec 21, 2024 6:48 am
ql401375676
Post by ql401375676 » Sat Dec 21, 2024 7:26 am
Yes, "erase" it like this:
- enable DDNS
- stop SE server
- connect to any VPN Gate server
- start SE server
- disable DDNS and disconnect from VPN Gate
The original SE server has been uninstalled and there is no key left. How can I restore the DNS name to its previous state and unbind it from the IP address after restoration
ql401375676
How to recover the previous DDNS name without a key
Post by ql401375676 » Sat Dec 21, 2024 7:59 am
I previously set up a DNS domain name of 'xxx. softether. net' and forgot to save the key. I still want to continue using the previous domain name. Is there a way to recover it
