Multiple softethers in lan.
mendoza_lt
Post by mendoza_lt » Fri Jul 25, 2025 10:00 am
Goosmorning,
I have just encountered strange thing... I have two softether servers in same lan. But when i want to make cascade connection from outside, i can only access one of them... I use domain/local ip combination as address (tried outside ip/local ip - same). No firewall forwards done for any servers exept one of them (reachable) has 1194 forward for openvpn. I tried to do port forward for "unreachable" server, used port 999 for test, but it still was unreachable... Both servers are reachable inside lan.
What do i miss?
Re: Multiple softethers in lan.
Post by solo » Fri Jul 25, 2025 10:43 am
Before we conclude tell us what happens when you disable NAT-T on the accessible cascade.
mendoza_lt
Post by mendoza_lt » Sun Aug 17, 2025 5:13 pm
Sorry for delayed response: problem solved, was mess in lan, rouge DHCP server...
