Disconnect time
ray5450
Disconnect time
Sometimes, when connected to a VPN server, it suddenly disconnects, usually when I am not present. Does Softether create a log or file so that I could know the time that happens? Thank-you.
Re: Disconnect time
C:\Program Files\SoftEther VPN Client\client_log
2025-08-04 09:52:39.137 Disconnecting the VPN Connection Setting "public-vpn-185".
2025-08-04 09:52:39.183 VPN Connection Setting "public-vpn-185": The connection has been either disconnected or it failed. Cause: The command has been canceled by user. (code 6)
