Can Cascade make a full mesh net?
zhouyut001
Post by zhouyut001 » Thu Aug 14, 2025 1:34 am
I have 5 nodes installed latest dev version from gitbub.
Every node created one HUB with one tap in one bridge.
I wanna make a full mesh network.but I got broadcast storm?
Node 1 to Node 2
Node 1 to Node 3
Node 1 to Node 4
Node 1 to Node 5
Node 2 to Node 3
Node 2 to Node 4
Node 2 to Node 5
Node 3 to Node4
Node 3 to Node5
Node 4 to Node5
Re: Can Cascade make a full mesh net?
Post by solo » Thu Aug 14, 2025 2:05 am
No
