As usual, I tried to launch the VPN, everything seemed normal, but it says that everything is connected, and there is an internet connection according to the system settings for the adapter, but nothing loads.
Restarting the system, creating a new adapter, reinstalling the application, and choosing a different server did not help.
The VPN isn't working; it says everything is connected, but nothing is loading
asdVPN
Re: The VPN isn't working; it says everything is connected, but nothing is loading
- import this VPN https://www.vpnusers.com/viewtopic.php? ... 53#p104376
- connect to it
- click http://get-my-ip.ddns.softether-network.net/
- if you don't see "IP=219.100.37.233" check your firewalls and try another browser
- connect to it
