Android & iPhone Clients for SoftEther That Support HTTPS
mpfrench
The SoftEther HTTPS cuts through firewalls like a hot knife through butter. Do an Android & iPhone clients exist that use HTTPS? If not, is anyone developing them? These cell phone clients would be extremely useful.
Re: Android & iPhone Clients for SoftEther That Support HTTPS
"SSTP Connect", "Open SSTP Client" and a newcomer, semi-commercial "ObfusGated VPN".
oscar
mpfrench
The firewall I'm trying to penetrate will pass only HTTP and HTTPS on the standard TCP ports 80 and 443, respectively. I tried using an SSTP client on a cell phone but the firewall blocked it.
It appears that the only solution is for someone to develop a cell phone app that uses HTTPS to communicate with SoftEther. This project would be wonderful for a grad student.
oscar
The solution is already there,mpfrench wrote: ↑Thu Mar 05, 2026 12:54 amThe firewall I'm trying to penetrate will pass only HTTP and HTTPS on the standard TCP ports 80 and 443, respectively. I tried using an SSTP client on a cell phone but the firewall blocked it.
https://apps.apple.com/us/app/sstp-connect/id1543667909
https://play.google.com/store/apps/deta ... ittoku.osc
https://play.google.com/store/apps/deta ... sgated.vpn
and advanced developers are even trying to implement more advanced version of them like sharing VPN over mobile hotspot & hosting a SoftEther VPN server in mobile eSIM
mpfrench
I tried your recommended SSTP clients. While the SSTP system uses TCP port 443, it apparently does not use the HTTPS protocol since the firewall I'm trying to penetrate refuses to let SSTP pass through. The Windows SoftEther client when set to use HTTPs does penetrate the firewall.
Again, someone needs to develop a SoftEther client for cell phones that uses the HTTPS protocol to solve this problem.
