I've managed to succesfull setup the VPN connection. The internal IP-range of the server/pc's are 192.168.0.x
Softehther gives the VPN-client 192.168.30.x, so far so good.
ONLY the 192.168.0.1 (older)server is possible to connect to or ping to.
The 2019 HyperV server, where the SoftEther VPN Server is running on (19.168.0.2) and an VM 192.168.0.3 are not reachable, not with mapping nor with ping.
Is there something i can check?
Regards,
Matt
VPN and networkmapping
Re: VPN and networkmapping
set: DisableKernelModeSecureNAT = 1
MLV
YES!! that did the job, thx.
