Hi there,
Is it possible to set Softether NOT to use the VPN-server internetgateway, only the IP-traffic needed to access the remote pc?
The remote PC has a max 50mbit connection and here at home 500mbit, the normal internet traffic on my pc at home is now routed through the VPN(when connected).
Regards,
Matt
VPN connection without gateway
Re: VPN connection without gateway
Hello again, you need a split tunnel.
