VPN Client Connects Successfully but No Internet Access
Rayhan785800
Post by Rayhan785800 » Fri Feb 13, 2026 10:44 pm
I am facing an issue with my SoftEther VPN setup and would appreciate your help.
I have installed SoftEther VPN Server on my office computer and set up the SoftEther VPN Client on my home computer. I followed the official setup guide step by step. The VPN client connects successfully to the server without showing any errors.
However, after the connection is established, I cannot access the internet from my home computer. Browsing and other online services do not work while the VPN is connected.
Could this be related to SecureNAT, Local Bridge, routing, or firewall settings? I would be grateful if someone could guide me on what to check or how to fix this issue
Re: VPN Client Connects Successfully but No Internet Access
Post by solo » Sat Feb 14, 2026 12:22 am
Rayhan785800
Post by Rayhan785800 » Sat Feb 14, 2026 12:47 am
Thank you for your suggestion regarding split tunneling.
To be honest, I am not very experienced with advanced internet or routing configurations. I followed the setup guide carefully, but I am not fully confident about checking or adjusting split tunnel, routing, or gateway settings on my own.
If you are willing, is it possible for you to connect to my system remotely (for example via AnyDesk) and help me check the configuration? I would really appreciate your assistance. If needed, I can also offer a tip for your time and support.
Thank you again for your help.
