to client and what does a client has to answer within which time.
Sorry I am CLI because pictures of documents are hardly to read
and I have to write not at any time.
Wich Informations have to go from host
feichtinger
Again German Translation
and no denglish if it never tries to be dUSerish as it always tries to be more and more slang. The translation of course should be made from absolut perfect japan language which I don't know. At any rate I'll make clear German which exists as all technical expressions do exist.
The drafts in the manual are to be forgotten because of most inferior quality, 600dpi are absolut minimum. Svg has to be normal, I will use TeX with postscript and no compromise.
feichtinger
Re: Wich Informations have to go from host
To answer directly no more explanation as necessary I declare to rewrite the manual because a line of logic is too hard to find
