Hello, I've come across a couple of security concerns with the Softether VPN Server
1. Old TLS versions by default TLS 1.0 and TLS 1.1 are enabled by default but there is a step that can be taken to disable the old protocols and leave 1.2 and 1.3 enabled.
2. Also by default if you go to https://yourpublicipaddress:5555 or whatever port your sever is on in a browser it displays this in a webpage
SoftEther VPN Server / Bridge
For VPN users:
Connect to this VPN Server
by Official SoftEther VPN Client (download)
by L2TP/IPsec, OpenVPN or SSTP traditional clients
For VPN administrators:
Manage this VPN Server or VPN Bridge
by SoftEther VPN Server Manager GUI for Windows / macOS (download) (Recommended)
by SoftEther VPN Command Line Management Utility (vpncmd) for CUI
by JSON-RPC API from your favorite programming language (JavaScript, TypeScript, Java, Python, Ruby, C#, ... etc.)
(ID: 'administrator', Password: same to the VPN Server's password. Default: empty)
by Built-in HTML5 Web Administration Console (New, under construction)
If you want to disable this embedded web server and JSON-RPC server:
Stop the daemon.
Modify the value of "bool DisableJsonRpcWebApi" from "false" to "true" on the vpn_server.config or vpn_bridge.config.
Restart the daemon.
Which I don't like cause it advertises what VPN software you're using. All they need now is to get the client and start trying to login at the bottom of the page it tells how to disable this.
So those are 2 security issues I see. Does anyone know of anything else that should be disabled to harden the security a bit more or turn off anything that's vunerable?
Security Concerns
khris2fer74
Security Concerns
Re: Security Concerns
Enable anti-MitM.
https://www.softether.org/4-docs/1-manu ... rification
https://www.softether.org/4-docs/1-manu ... entication
Enable TunnelCrack protection.
https://www.softether.org/9-about/News/905-TunnelCrack
Pick chained ciphers.
viewtopic.php?t=68790
Adapt VPN Gate packet filtering rules.
viewtopic.php?f=7&t=68039#p97841
Apply IP Access Control List.
https://www.softether.org/4-docs/1-manu ... ntrol_List
Consider VPN Gate's "deny_bridge" option.
https://www.softether.org/4-docs/1-manu ... on_Options
(this would make some users cry, LOL viewtopic.php?t=70058 and viewtopic.php?t=70105 )
While at it, for other reasons disable DDnsClient and NatTraversal if you don't need them.
viewtopic.php?f=7&t=67838#p97405
