Client to client Connectivity
matty930
Post by matty930 » Fri Oct 06, 2023 11:04 am
Hi Guys
I have setup the the VPN server no issues, one thing I could do with is allowing clients to be able to connect to each other, For example;
configured the VPN subnet to 192.168.30.0/24
each client gets an ip of 192.168.30.* no issues there
However I need a device with say 192.168.30.10 to connect and access shares on 192.168.30.11 but I can't seem to figure out how to do it.
Can anyone please shed any light or help with this?
Thanks in advance.
Re: Client to client Connectivity
Post by solo » Fri Oct 06, 2023 12:20 pm
On 192.168.30.10 run: explorer \\192.168.30.11\share-name
If it does not work, set up your OS properly, it has nothing to do with VPN.
matty930
Post by matty930 » Fri Oct 06, 2023 12:39 pm
I can't ping between them either, and yes ICMP is open on both devices, so presume the SoftEther VPN server isn't routing between them.
Post by solo » Fri Oct 06, 2023 12:52 pm
Connect VPN and post as code from both clients:
netstat -r
ipconfig /all
ping 192.168.30.1
netsh advfirewall firewall show rule name="File and Printer Sharing (Echo Request - ICMPv4-In)"
matty930
Post by matty930 » Fri Oct 06, 2023 1:36 pm
Many thanks this was enough!
I have one of the devices using the SoftEther VPN client and I didn't notice it created the interface using the public profile doh!
Thanks for the help
