CLIENT CAN'T CONNECT TO THE VPN SERVER
rafin
Post by rafin » Thu Jun 27, 2024 3:56 pm
hey i need some help over here the issue is i recently decided to host my own Minecraft server from pc so that i can play with my buddies, but it turns out im behind a GCNAT and cant afford a public ip for now so i did some searching on google and came across softether vpn i watched some yt videos to set it up
[i did the firewall stuff, enabled azure , all the port were listening, I also opened those default port on the router ] created a hub set that up but then tried to join i was unable to join it , the joining thing just loops i did double check i did use the azura host name and port 443 my auth pw were right
this is so frustrating please help me troubleshoot this issue
Re: CLIENT CAN'T CONNECT TO THE VPN SERVER
Post by solo » Thu Jun 27, 2024 5:15 pm
rafin
Post by rafin » Fri Jun 28, 2024 1:18 pm
forget about gaming it's not even connecting to the vpn server whatsoever its just loops in connecting page
Post by solo » Fri Jun 28, 2024 4:10 pm
The free VPN Azure gateway is down occasionally. If you can't put up with it, or drop CGNAT ISP then forget about gaming indeed.
