Connect to a VPN on android using OpenVPN.
Locked
Wallesss
Post by Wallesss » Wed Oct 02, 2024 1:18 pm
Hello, I can't connect to a VPN on a Huawei tablet using the OpenVPN configuration file from VPNGate (see the file "vpngate_opengw.opengw.net_udp_1194.ovpn.txt"). In the file "debug_info.txt" the connection error log is attached.
Why can't I connect to the VPN server using any OpenVPN configuration file?
Re: Connect to a VPN on android using OpenVPN.
Post by solo » Wed Oct 02, 2024 11:14 pm
Locked
