Installation of Virtual Network Adapter device driver failed
Locked
suki__
Post by suki__ » Fri Dec 27, 2024 2:44 am
Device running on SnapDragon/ARM processor. (Understand that Softether is only available on Intel)
Anyway to solve this?
Would appreciate any help
Re: Installation of Virtual Network Adapter device driver failed
Post by solo » Fri Dec 27, 2024 3:21 am
Use native SSTP or get OpenVPN client.
EDIT
2026-11-05 update, try the new v5 ARM versions.
softether-vpnclient-5.02.5187.arm64.exe
sha256:89389881f55abcd6194ccc3dbba943ca55899b962508e1d5d7e17a4d97c7ea3e
40.9 MB 2026-11-05T09:04:37Z
softether-vpnserver_vpnbridge-5.02.5187.arm64.exe
sha256:61faa27798b920946cac3ed30a26661412c836e5ba118c38704152978e8c9373
44.9 MB 2026-11-05T09:04:40Z
https://github.com/SoftEtherVPN/SoftEtherVPN/releases
scottjameson
Post by scottjameson » Thu Jan 09, 2025 7:39 pm
The OpenVPN client can be configured to connect to a SoftEther VPN server? The native Windows 11 VPN client configured with SSTP protocol will connect to a SoftEther VPN Server? Do either of these allow automatic connection after computer restart and/or Windows user login? Thank you.
scottjameson
Post by scottjameson » Thu Jan 09, 2025 10:59 pm
The OpenVPN client can be configured to connect to a SoftEther VPN server? The native Windows 11 VPN client configured with SSTP protocol will connect to a SoftEther VPN Server? Do either of these allow automatic connection after computer restart and/or Windows user login? Thank you. Tried exporting Sample config file for OpenVPN client connection from SoftEther VPN Server. Imported on client computer, it keeps connecting and disconnecting from VPN server over and over. Is there a manual way to install the Virtual Network Adapter device driver for SoftEther client, or a way to troubleshoot why it won't install through the GUI?
Post by solo » Fri Jan 10, 2025 3:26 am
suki__ wrote: ↑
...because viewtopic.php?f=7&t=69508#p102938
https://www.vpngate.net/en/howto_sstp.aspx
https://www.vpngate.net/en/howto_openvpn.aspx
thuhien88
Error create a New virtual Network Adapter in Surface laptop 7
Post by thuhien88 » Fri Jun 19, 2026 3:09 pm
Hello, I'm using Surface Laptop 7 Snapdragon X Plus. I install softEther
VPN Client Manager. The system reports successful installation, but I
can't create a New virtual Network Adapter. I look forward to your support and guidance. Thank you!
Locked
