Dear Team
I have setup a softether vpn server with the softether remote client application (no bridge), both my server and pc are at remote locations and having ip address in the 192.168.1.0 range, my server ip 192.168.1.12 has rdp eanbled on it for which i can remotely connect, my router ip is 192.168.1.1 and at the server network the router ip is the same at 192.168.1.1 since the network gets joined would it then cause a conflict while logging in the routers at 192.168.1.1 at the client or server side ?
Regards....
Would a Router IP conflict occur for a Softether Server Client connection?
sydney01
Re: Would a Router IP conflict occur for a Softether Server Client connection?
そうですね。
同一ホストで同じネットワークアドレスを使用する複数のネットワークに同時に接続した場合、どちらかは通信できなくなります。
