connected to server but can't browsing
cat
Post by cat » Sat Mar 16, 2013 10:20 am
Hi
i've made vpn server with softether vpn on debian 32bit.
client (my comp) is win 7 64 bit.
It succesfully connected, but after connected can't browsing. Ping is working normally.
Any advice? TIA.
Re: connected to server but can't browsing
Post by cedar » Sun Mar 17, 2013 3:33 am
What did you want to browse?
If you want to browse the VPN server's host PC, you should use tap mode local-bridge.
cat
Post by cat » Sun Mar 17, 2013 4:45 am
> local-bridge.
I want to browse internet (ex youtube.com). I connect it on wifi that only allow icmp packet (i hope can bypass it with softether). VPN over ICMP is enable on my server. It successfully connected but still can't browse internet.
Post by cedar » Sun Mar 17, 2013 12:48 pm
Your client's virtual NIC have been assigned a proper IP address?
If you don't have DHCP server in your server's segment, you can use also a virtual DHCP server function.
cat
Post by cat » Mon Mar 18, 2013 1:31 am
I thought it assigned proper IP address & DHCP server it's enable. Please see screenshot below & in attachment, maybe you can find the problem. Thank you.
http://postimage.org/image/vuqth0x1t/
Post by cedar » Mon Mar 18, 2013 2:25 am
VPN client don't manage the virtual NIC's IP address.
Please check IP address in 'Network Connections' of the control-panel instead of VPN client.
cat
Post by cat » Mon Mar 18, 2013 2:58 am
attached is from Control Panel\All Control Panel Items\Network and Sharing Center
what should i do so VPN client can manage the virtual NIC's IP address ?
Post by cedar » Mon Mar 18, 2013 4:18 am
There is nothing to do on VPN client.
It seems that the virtual NIC didn't get an IP address from DHCP server.
Is there any DHCP server on servers side network?
If you don't have DHCP server, please enable virtual DHCP server function on the virtual hub.
cat
Post by cat » Mon Mar 18, 2013 6:15 am
> i've enabled SecureNat & now problem solved. Thanks for your help. Great software
> :D.
That's me. Forgot to login lol :p
