SecureNatStatusGet - Kernel-mode NAT is Active
calimansi
Post by calimansi » Sun Mar 17, 2013 2:17 am
Does anyone know what "Kernel-mode NAT is Active" is referring too? Right now, mine says No, but I'm using a local bridge to a tap interface. If I could enable the kernel mode NAT, I think I could have a fully working system with good performance.
Thank you.
Re: SecureNatStatusGet - Kernel-mode NAT is Active
Post by cedar » Sun Mar 17, 2013 3:41 am
To work the Ketnel mode NAT mode, the host have a nic which can receive an IP address and gateway router which can reach the Internet from DHCP server.
