Export User List
emadneb
Export User List
Post by emadneb » Thu Apr 11, 2013 2:55 pm
Hi anybody know how can I export my USERs (in Manage User section)?
I want to transfer my user list to another IP
Re: Export User List
Post by cedar » Fri Apr 12, 2013 12:45 am
There is no way to export only the user information.
Please use the configuration file directly.
emadneb
Post by emadneb » Fri Apr 12, 2013 1:20 am
tanX, thats worked :)
onlyenglish
Post by onlyenglish » Fri Apr 12, 2013 10:38 pm
Hello, which configuration file is it? What is the exact filename and where to find?
Thanks.
Post by cedar » Sat Apr 13, 2013 10:33 am
You can acquire configuration file from the Server manager.
You can also find out the configuration file in installation folder.
The name of the configuration file is 'vpn_server.config'.
jjvargas
Post by jjvargas » Wed Sep 13, 2023 10:04 pm
emadneb wrote: ↑
Hello, I'm trying to do the same thing to the new server but I replaced the file and it didn't work, could you tell me how you did it. Thank you
jjvargas
Post by jjvargas » Wed Sep 13, 2023 10:18 pm
onlyenglish wrote: ↑
Thanks.
Post by solo » Wed Sep 13, 2023 11:34 pm
jjvargas wrote: ↑
... I replaced the file and it didn't work, could you tell me how you did it. Thank you
net stop SEVPNSERVER
copy vpn_server.config "C:\Program Files\SoftEther VPN Server\vpn_server.config"
net start SEVPNSERVER
