I`m using SOftether on windows server 2008
Is there any way to add new user without using remote to server ?
like CCproxy (web remote access to create or edite users)
Add new user without remoting on server ?(windows server)
Re: Add new user without remoting on server ?(windows server
To which of a VPN server and Windows would you like to add a user?
Iwant to add user on softether vpn, without remoting to windows,
is there another way to add users linke WEB ACCESS or sthg like that ?
Hi
Just install the server manager on your computer (on which you want to connect to server) and in new setting add your server.
How Connect To my sever Wtih Manager
But when install soft ether Vpn Clinet Manager and connect to server failed thsi action
when running server manager from your workstation, you have to connect as administrator. You must know the password of it as you have installed the server. You must be on the same lan of course. not remotely.
Once done,
You must also do some port redirection on your main router to redirect vpn requests sent to your softether vpn server else you will go nowhere.
Once done,
