Hi buddies,
I have VPS (VMware ESX Tech.) with this configs:
CPU: 1 x 2GHz
RAM: 1GB
NIC: 1 NIC (Internet Connection)
I need connect to this server and use it's internet for bypass my ISP limited.
Now VPS configured by SecureNAT on softEther, but my speed is very slow.
In softEther document said, Local Bridges is better than secureNAT and speed is well.
For Local Bridges:
1. Removed SecureNAT
2. In [Local Bridge Setting], Local Bridge created between VPN-HUB and NIC
But, SoftEther Client's VNIC can't get IP Address when i connected to server.
Please Help me
Thanks
[Problem] Local Bridge on VPN Server
Re: [Problem] Local Bridge on VPN Server
Localbridge is a function for remote-accessing to the LAN.
Not suitable for VPS.
sorset
So if there is a internet gateway in LAN network, can we make our connection trough this gateway by softether?
Or in another way, can we make sofether client adapter be default adapter to route? If we use local bridge on server.
Please use the SecureNAT function although its performance is low.
sorset
But I have some problems with SecureNAT because of its low performance :(
There is no easy way to solve the problem.
You can configure NAT service in your VPS and connect it to the virtual hub.
A standalone NAT service may run faster than SecureNAT function of SoftEther VPN.
