High CPU load on enabling NAT
sorset
Hi
I'm using Packetix VPN server on ubuntu running on VPS.
I have problem , when I enable secure NAT , I see high load on cpu by vpnserver and clients speed will be decreased.
I dont use any localbridges , and server communication is directly through eth0.
whats the problem?
whats the problem?
Re: High CPU load on enabling NAT
Please check packet log to find suspicious traffic.
The kernel-mode NAT function may cause this problem.
Please disable kernel-mode NAT in advanced virtual hub option.
sorset
Thank you ,I did but the problem not solved :(
I found in . VIrtual HUB Properties --> Edit Virtuak HUB Extended Option list --> Disable kernelmod Secure NAT , and I set it to 1 :-s
But still hsve problem, im using OpenVZ...
sorset
In addition, when there is no VPN session over NAT there is no unusual load, but when a user connets even with low traffic I see about 100% load on cpu.
Didn't you find some unusual traffic in packet log or system monitor?
sorset
Thank you for answering.
I'm sure that there is just one NAT user session that is my pc (windows 7 64bit) and im just connected to server's ssh for checking cpu stats. And there is no other internet or network traffic.
When I connect to vpn after a while cpu load will be at its maximum level.
I tested on ubuntu 64bit, centos 32bit and windows server 2003 32 bit
All of them have this problem with NAT.
All of the settings are default and there is no bridge. And other vpn services are disabled.
Wich logging file can be useful? I can share with you.
Please enable whole Ethernet packet log of the virtual hub temporarily.
This log may grow to huge size to upload.
Please read it yourself firstly.
sorset
Hi
I saw that CPU load will be at 100% , even NAT user be disconnected , untill I disable secure nat or stop server!
I Think it can be softehter secureNAT bug!
So I enabled full logs, stopped the server, cleared all logs , then started server and when I see that CPU load , after about 15 seconds I stopped server.
Here is full logs... I don't see any suspicious log :(
Would you please see these logs?
thanks
http://filetrip.net/dl?wSQbpzM8cR
thanks
I don't find out suspicious log too.
SecureNAT is a most heavy function on SoftEther VPN Server.
CPU power of the VPN server host may be too low to use this function.
Try to use other NAT system such as OS embedded NAT function.
sorset
You mean it's not something like infinite loop in softether secureNAT?
OK , I'll try another one. thank you for helping.
Lord Farhad
Sorset I'm having the same problem, did you find any solution to this?
sorset
Just try another server with stronger CPU ;)
That's already solved for me.
hyper
what's cpu was good for you?
and how many online clients can support?
sorset
Im using on virtual machine , with 4 cores cpu.
hyper
thanks for your reply
abdullah2
wow thanks this method make my CPU not 99% again for now
mbrcomp
Thank you, saved my bacon !!! Weird option !
pribr
I solved the problem by changing the local bridge settings, in creating a tap device instead of a bridge device.
amm
i couldnt fix this in ubuntu server no matter what ( disabling securenat kernel mode dint even disable it ) so im using CentOs 8 and problem solved now and everything is fine
Johnnypaul
I have a Cisco 7513 and then I have four Cisco 3640's out in the field hanging off the 7513 via Serial ports. Each Cisco 3640 has 4 t1's feeding to the 7513. Just last week I took NAT off the Cisco 3640's (due to high CPU usage) and added one big NAT pool on the 7513, all traffic from the 3640's feed into this one nat pool on the 7513 and then out my 100 Meg pipe to the internet. I have about 2000 High speed internet customers running off these 3640's. Before I enabled NAT on the 7513 my CPU ran about 30%, now that I have NAT running the CPU will sit at about 85%. But hopefully this (https://techloris.com/wmi-provider-host-high-cpu/) solved my high CPU usage.
praveendhaka8
SIZE=5 hellodear.in
teatv
SIZE=5 hellodear.in
teatv
