Virtual hub internal DHCP assign same address to same client
altuin
Post by altuin » Tue Apr 16, 2013 11:17 am
Is it possible to configure the internal dhcp server in such a way that it would assign the same ip address to a client after the client reconnects? If it is, would it function based on mac filtering or username filtering? I already tried setting the lease time to 0 (default is 7200) but the ok button becomes greyed out once I select 0.
Thanks in advance!
Re: Virtual hub internal DHCP assign same address to same cl
Post by cedar » Wed Apr 17, 2013 1:31 am
Virtual DHCP server function assigns IP address based on MAC address.
But this MAC-IP table is not persistent.
If you want to manage properly, it makes more sense to use the external DHCP server.
altuin
Post by altuin » Wed Apr 17, 2013 7:09 am
My purpose is to connect different clients to different virtual hubs so I don't think using an external DHCP server will solve my problem. I need different ip classes for the virtual hubs so that clients are not able to see each other's networks.
Thank you!
Post by cedar » Thu Apr 18, 2013 12:38 am
You can use DHCP server host with VPN Client to assign different network address for each hub.
