logging problem
votes
logging problem
Post by votes » Tue Apr 23, 2013 8:49 am
Hi all!
I have two problem with logging.
First I can't set log options on virtual HUB
I go Management Virtual HUB -> other settings -> "Log Save Settings"
The button "Log Save Settings" is grey and not focusable (I can't click them)
Description "Configure of log saving function." is grey too.
Second problem
When I configure packet logging from VPN CLI i see in logs
".....The VPN Server is either Open-Source or Free version. It hasn't implemented the IP Address or TCP/UDP header data logging function. No IP address nor TCP/UDP header data are not be recorded here.,-,-,-,-,-,-,-,-,-"
Piter
Re: logging problem
Post by cedar » Wed Apr 24, 2013 6:45 am
Detailed packet logging function is for commercial version.
Please use other packet capture software to monitor packets in a virtual hub.
votes
Re: logging problem
Post by votes » Wed Apr 24, 2013 10:11 am
Hi!
Thanks for answer.
But why I cant set any options from GUI (first part of my question)
I have manual
http://www.softether.org/4-docs/1-manua ... ng_Service
"Changing the Virtual Hub Log File Settings"
I cant open this box and set loging shedule or enable/disable security log (no packet log)
because i cant do this
"First I can't set log options on virtual HUB
Description "Configure of log saving function." is grey too."
PS default rule save packet TCP connections header and we have log with no ineresting string no implemented and we cant off them from GUI.
Piter
Re: logging problem
Post by cedar » Wed Apr 24, 2013 3:16 pm
Online Manual is shared with the commercial version.
Some features that are not available in the free version is covered.
