How to Active kernel-mode NAT?
sorset
Post by sorset » Mon Apr 29, 2013 9:34 pm
Hi
I'm using packetix vpn server on ubuntu.
In Secure NAT operating status I see hat Kernel-mode NAT is not activated. wile its not deactived in hub properties.
How can I active this module? should I compile anything?
Re: How to Active kernel-mode NAT?
Post by cedar » Tue Apr 30, 2013 2:00 am
Kernel mode NAT function needs two conditions to work.
1. DHCP service in some Ethernet device of the host.
2. Default gateway assigned by the DHCP with Internet access.
sorset
Post by sorset » Tue Apr 30, 2013 2:57 am
Thank you.
So if these conditions be exist , what should I do?
Post by cedar » Tue Apr 30, 2013 4:09 am
SecureNAT tests these conditions automatically.
There is nothing to do specially.
sorset
Post by sorset » Tue Apr 30, 2013 9:00 am
Do you mean that when these conditions are available , It will be activated automatically?
Thank you.
