Some features
metalik
Some features
Post by metalik » Mon May 06, 2013 4:36 am
Hello
Thank you for your great software.
1. Is it possible to add SoftEther VPN Protocol (Ethernet over HTTP)? (HTTP instead of HTTPS)
2. In our country all vpn and proxies works only for 30secs to 1min and then it will not disconnect but it does not work. Can you investigate this and provide a solution?
3. How can we user vpn over icmp? (I have enabled this option but i don't know how can connect)
Regards
Re: Some features
Post by cedar » Tue May 07, 2013 4:50 pm
It's possible.
But it may be not easy.
SoftEther VPN can bundle multiple TCP connection to a session.
Please try to set connection interval to 20 secs.
Specify a server address simply.
In ICMP mode, port number is not referred.
